Hi I am running four tasks on an STM32H7 they are:
monitorTask - runs with a vTaskDelay 0f 250 ms Prio. = osPriorityNormal2
posRecordTask - runs with a vTaskDelay 0f 2 ms Prio. = osPriorityBelowNormal
wiFiStartupTask - runs once then deletes itself - Prio. = osPriorityNormal1
wiFiTask - runs continuously - Prio = osPriorityNormal
All the tasks are static, the semaphores are dynamic.
All tasks have large stacks at 2048 words.
I have the ICACHE and DCACHE enabled, but the semaphore handle is in the DTCM memory which isn’t cached.
It is the interaction between the startWiFiTask and wiFiTask that causes the issue.
At startup the startWiFiTask runs first to set up a WiFiModem using “AT” commands over the SPI bus. On completion of the startup this task starts the wiFiTask then deletes itself.
The wiFiTask looks after the data transport of the modem. If the connection is lost during the listening process the wiFiTask restarts the startWiFiTask and then deletes itself. This cycle will repeat successfully up until a point where upon entry to the startWiFiTask and on executing
the xSemaphoreTake(wiFiReadySemHandle, (uint32_t)0U); statement the config assert of the semaphore handle fails and the program stops in the freeRTOSConfigAssert module; vAssertCalled.
I have stack checking 2 enabled and upon entry to the vAssert all stacks are OK, no overflow.
I changed the semaphore wiFiReadySemHandle to a static implementation and then the system runs without error.
I have checked all of my interrupts to ensure they are => configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
I checked I wasn’t calling non ISR FreeRTOS functions from within interrupt routine. That was OK.
The functions that initialize and restart the wiFiStartup task are:
#define STACK_SIZE_START_WIFI_TASK 2048
StackType_t __attribute__((section (".DTCM_MISC"))) startWiFiTaskStack[STACK_SIZE_START_WIFI_TASK];
StaticTask_t __attribute__((section (".DTCM_MISC"))) startWiFiTskBuffer;
#define STACK_SIZE_WIFI_TASK 2048
StackType_t __attribute__((section (".DTCM_MISC"))) wiFiTaskStack[STACK_SIZE_WIFI_TASK];
StaticTask_t __attribute__((section (".DTCM_MISC"))) wiFiTskBuffer;
TaskHandle_t __attribute__((section (".DTCM_MISC"))) startWiFiTskHandle = NULL;
TaskHandle_t __attribute__((section (".DTCM_MISC"))) wiFiTskHandle = NULL;
SemaphoreHandle_t __attribute__((section (".DTCM_MISC"))) wiFiReadySemHandle = {0};
* Start the WiFi Initialisation task and Network Time Task if defined 1
WIFI_StatusTypeDef startWiFiSystem(wifiParsTypeDef* wiFiPars)
wiFiReadySemHandle = xSemaphoreCreateBinary();
startWiFiTskHandle = xTaskCreateStatic(wiFiStartupTask,
"wifiStartup",
STACK_SIZE_START_WIFI_TASK,
wiFiPars,
osPriorityNormal1,
startWiFiTaskStack,
&startWiFiTskBuffer);
if(startWiFiTskHandle == NULL)
return WIFI_STARTUP_TASK_FAILED;
return WIFI_OK;
* CREATE AND START WIFI TASK
WIFI_StatusTypeDef startwiFiTask(wifiParsTypeDef* wiFiPars)
wiFiTskHandle = xTaskCreateStatic( wiFiTask,
"wifiTask",
STACK_SIZE_WIFI_TASK,
wiFiPars,
osPriorityNormal,
wiFiTaskStack,
&wiFiTskBuffer);
if(wiFiTskHandle == NULL)
return WIFI_XPORT_TASK_FAILED;
return WIFI_OK;
* RESTART WIFI
void restartWiFiTask(void)
startWiFiSystem(&wiFiPars);
vTaskDelete(wiFiTskHandle);
The failure of the asset occurs at the first semaphore take in the startWiFiTask:
* File Name : wiFiStartupTask.c
* Created On : 23 Dec. 2021
* Description :
* Author : R J Garnett - Admin
#pragma GCC optimize ("Ofast") /* rjg todo */
//#pragma GCC optimize ("O0") /* rjg todo */
* Start Up Task
* This does the following:
* - Hardware resets the WiFi module via WIFI_RST_Pin => PI4
* - Connects the modem as a Station (STA) to the designated SSID
void wiFiStartupTask(void *argument)
WIFI_START_LBL:
vTaskDelay(20); /* Allow wiFiTask to complete and close */
noWiFiStarts++;
printfdma("%05d WiFi Startup Start\r\n", noWiFiStarts);
wifiParsTypeDef *wf;
wf = argument;
HAL_GPIO_WritePin(USER_LED2_GPIO_Port, USER_LED2_Pin, GPIO_PIN_SET);
__HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_5);
wiFiErrorState = WIFI_OK;
wiFiRdyState = HAL_GPIO_ReadPin(WIFI_DATRDY_GPIO_Port, (uint16_t)WIFI_DATRDY_Pin);
/* Clear semaphores to prevent nastiness */
xSemaphoreTake(wiFiReadySemHandle, (uint32_t)0U); /* Assert raised here */
/* Main task loop */
while(1)
/************ 1 Send a reset to the Wi Fi module ***********/
wiFiModuleReset();
if (xSemaphoreTake(wiFiReadySemHandle, (uint32_t)WI_FI_RESET_TIMEOUT) == pdFAIL)
/* Long list of AT commands sent to the modem */
/* Delete the startup task */
printfdma("%05d WiFi Startup End\r\n", testCounterWiFiTask);
vTaskDelete(startWiFiTskHandle);
My FreeRTOS Config is:
#ifndef CMSIS_device_header
#define CMSIS_device_header "stm32h7xx.h"
#endif /* CMSIS_device_header */
#define configENABLE_FPU 0
#define configENABLE_MPU 0
#define configSUPPORT_STATIC_ALLOCATION 1
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( SystemCoreClock )
#define configTICK_RATE_HZ ((TickType_t)1000)
#define configMAX_PRIORITIES ( 56 )
#define configMINIMAL_STACK_SIZE ((uint16_t)128)
#define configTOTAL_HEAP_SIZE ((size_t)15360)
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
#define configCHECK_FOR_STACK_OVERFLOW 1
#define configUSE_TASK_NOTIFICATIONS 1
/* USER CODE BEGIN MESSAGE_BUFFER_LENGTH_TYPE */
/* Defaults to size_t for backward compatibility, but can be changed
if lengths will always be less than the number of bytes in a size_t. */
#define configMESSAGE_BUFFER_LENGTH_TYPE size_t
/* USER CODE END MESSAGE_BUFFER_LENGTH_TYPE */
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( 2 )
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH 256
/* The following flag must be enabled only when using newlib */
#define configUSE_NEWLIB_REENTRANT 1
/* CMSIS-RTOS V2 flags */
#define configUSE_OS2_THREAD_SUSPEND_RESUME 1
#define configUSE_OS2_THREAD_ENUMERATE 1
#define configUSE_OS2_EVENTFLAGS_FROM_ISR 1
#define configUSE_OS2_THREAD_FLAGS 1
#define configUSE_OS2_TIMER 1
#define configUSE_OS2_MUTEX 1
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend
#define INCLUDE_vTaskDelayUntil
#define INCLUDE_xTaskGetSchedulerState
#define INCLUDE_xTimerPendFunctionCall
#define INCLUDE_xQueueGetMutexHolder
#define INCLUDE_uxTaskGetStackHighWaterMark
#define INCLUDE_xTaskGetCurrentTaskHandle
#define INCLUDE_eTaskGetState
* The CMSIS-RTOS V2 FreeRTOS wrapper is dependent on the heap implementation used
* by the application thus the correct define need to be enabled below
#define USE_FreeRTOS_HEAP_4
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 5
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
/* USER CODE BEGIN */
extern void vAssertCalled( const char *pcFile, uint32_t ulLine );
#define configASSERT( x ) if( ( x ) == 0 ) vAssertCalled( __FILE__, __LINE__ )
/* USER CODE END */
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
/* IMPORTANT: After 0.3. update, Systick_Handler comes from NVIC (if SYS timebase = systick), otherwise from cmsis_os2.c */
#define USE_CUSTOM_SYSTICK_HANDLER_IMPLEMENTATION 0
I am at a loss as to what is going wrong. It would seem the semaphore handle is getting set to zero, but I don’t know how to determine the cause of this.
Has anyone had this problem before or has anyone any ideas on where to look for a cause. Setting the semaphore as a static to work around the problem is a satisfactory solution as it never gets deleted, but I would like to know what I am doing wrong that causes the dynamically assigned semaphore to fail.
Regards
Rob
