Hi everyone, i am a brazilian computer science student and i choose the FreeRTOS as SO to develop some study cases about testing. Since i started i am using both caps, the programmer cap and the tester cap, and you know, that is not the best practice when we talk about research.
My work focus on testing simple real time systems with interruptions, at this moment i am with the oWatcom compiler in a x86 PC port and with the Education kit of LPCxpress 1768.
So, if you have any source code with these characteristics and want to share with us, answer this post or send me a message, i will be really happy.
It is not clear what you are asking for. The FreeRTOS download is stacked full of code examples in the FreeRTOS/Demo directory. The book also comes with 16 or 18 simple examples, depending on the book edition. Or are you asking for test code?
Ahh ok, i am asking for a real code example. Something extra, the examples on the book, as you said, are simple… I need something a bit larger that uses interruptions. The code could be codified in another platform, but with that functionalities .
you should try downloading the book examples code and run its with watcom and dosbox. later you should try to run de examples in the evaluation board with soport for FreeRTOS.
OK, Thanks for your answers, i have the book and the examples here with me, i will use them to learn a bit more. But if you still know somebody with a real application to send me, i appreciate.
