I’m a little confused about the different between taskENTER_CRITICAL and taskDISABLE_INTERRUPTS.
I read the user manual, it said "they working by disabling interrupt……Pre-emptive switch can only occur from interrupt, so as long as interrupt remains disabled, the task called the taskENTER_CRITICAL can guaranteed to remain in running state ". From my understanding, both of them can result in disabled interrupt and context switch. Any tips?
ENTER_CRITICAL() keeps a count of the call nesting and is the only one you should use really. It normally calls DISABLE_INTERRUPTS internally.
Some but not all ports can still context switch with interrupts disabled, but not from in a preemptive way because with interrupts being disabled they cannot be preempted.
thanks davedoors for your answer, but I am still not very clear. Is there any ‘extra benefit’ ENTER_CRITICAL could provides, besides disabled interrupt.
They seem to be the same to me. I can’t tell the differences betweens them. Then I start wonder why do I need two different interface, if they share nearly the same features. I guess there should be something unknown to me.
Critical sections should not be storing the “stacking” of them on the stack, but tend to use a counter.
Some ports may use push/pop to access a status/control register. One thing to note is that a critical section may not disable ALL interrupts, but may just disable those interrupts at a level which is allowed to interact with the kernel, and this is sometimes done by setting the current interrupt priority level in the hardware.
