bjarkegelsted wrote on Tuesday, June 09, 2009:
What is the difference between portENTER_CRITICAL() and taskENTER_CRITICAL()?
rtel wrote on Tuesday, June 09, 2009:
There isn’t any difference. portENTER_CRITICAL() is part of the port layer and is not intended for application use. taskENTER_CRITICAL() is part of the API and is intended for application use, although one just calls the other so in reality it makes no difference.
thank you
