hiddenbitious wrote on Saturday, July 05, 2014:
Hello all. I’ll try to be brief with my problem.
I’m working on a zynq 702 board which is programmed with a custom hardware. Currently i’m adapting the CORTEX_A9_ZYNQ demo for my purposes.
The hardware, on certain occasions, raises an interrupt which i’m trying to catch and by using a semaphore to synchronize my task with my hardware. So far i have managed to catch the interrupt but i’m getting an assertion failure at tasks.c:2360 (configASSERT( pxUnblockedTCB )
My code:
Modified Demo/CORTEX_A9_Zynq_ZC702/RTOSDemo/src/FreeRTOS_tick_config.c: vConfigureTickInterrupt()
// Install the foo ISR.
extern void rtos_fooISR(void *data) /*__attribute__ ((isr))*/;
/// (notice i don't use the __attribute__ (isr), more on this later)
XScuGic_SetPriorityTriggerType( &xInterruptController, 90, (configMAX_API_CALL_INTERRUPT_PRIORITY) << portPRIORITY_SHIFT, ucRisingEdge);
xStatus = XScuGic_Connect( &xInterruptController, 90, (Xil_ExceptionHandler) rtos_fooISR, NULL);
configASSERT( xStatus == XST_SUCCESS );
( void ) xStatus;
XScuGic_Enable(&xInterruptController, 90);
Somewhere in main i initialize the binary semaphore:
BaseType_t status;
(void) status;
/// Initialize semaphore
foo_Semaphore = xSemaphoreCreateBinary();
configASSERT(foo_Semaphore != NULL);
status = xSemaphoreGive(foo_Semaphore);
configASSERT(status == pdTRUE);
Here is the ISR:
static BaseType_t xHigherPriorityTaskWoken = 0;
static volatile unsigned int *reg_addr = (unsigned int *)(BASE + foo_INTERRUPT);
(void) data;
/// Clear interrupt
*reg_addr = 0x1;
/// “give” semaphore
/// xil_printf(“g\n\r”);
xSemaphoreGiveFromISR(foo_Semaphore, &xHigherPriorityTaskWoken);
And this is the function the task calls when it wants to synchronize with the hardware
void rtos_waitForfoo(void)
xil_printf(“t\n\r”);
xSemaphoreTake(foo_Semaphore, portMAX_DELAY);
Is my code correct or i’m using a hack without being aware of it? Any idea why i get the assertion failure?
Also when i declare the rtos_fooISR function with the attribute((isr)) it appears that the interrupt stays on for ever. Why is that?
Thanks for your time.
