lucaszampar wrote on Tuesday, December 06, 2011:
Dear sirs,
I´m having a problem with Arm simulator on Crossworks 2.1 and Keil running with GCC.
I´m running FreeRTOS 7 and when I run the application on board with J-link connected everything works ok! Run and debug.
But when I use the “Arm Simulator” from crossworks or keil the application goes to HardFault exception.
With Keil, the FreeRtos goes to HardFault using the J-link too. But if I program the LPC and put to run, the board run.
I´m using GCC, and LPC1754.
Have any configuration to do on simulator or any workround?
PS: The new FreeRTOS need modifications to work with new Rowley Cross Studio (2.1). Its says that have a error with duplicate functions sprintf and sfprintf.
Tnks,
Lucas
