rclub123 wrote on Wednesday, September 28, 2016:
How to create two task such that one task runs at 0.5millisecond and another task runs at 100 millisecond using RTOS?
davedoors wrote on Wednesday, September 28, 2016:
Use vTaskDelayUntil() http://www.freertos.org/vtaskdelayuntil.html see the example on the page. 0.5ms is very fast though best to trigger from an interrupt.http://www.freertos.org/vTaskNotifyGiveFromISR.html
Thanks for your reply… i followed that link you provided… it is in the ticks… means it perfoms the task after 10 ticks… but i want this in milliseconds… i want task to execute after 0.5 milliseconds and 100 millisecond… how could i achieve that?
My clock freq and tick rate is as below
#define configCPU_CLOCK_HZ ((unsigned long)96000000)
#define configTICK_RATE_HZ ((portTickType)1000)
edit:
After reading some forums i understood about tick… so configTICK_RATE_HZ=1000 means in 1 second OS will generate 1000 ticks… but i dont know how to get 0.5 milliseconds (because there is nothing like 0.5 ticks for 1000kHZ)… i think i need to change configTICK_RATE_HZ… Am i right?
rtel wrote on Wednesday, September 28, 2016:
If configTICK_RATE_HZ is 1000, then the tick frequency will be
1000Hz/1KHz. So one tick every ms, and a timing granularity of 1ms (so
specifying a 1ms delay will give you between 0.0001ms and 0.9999ms).
You cannot specify a 0.5ms delay time with a 1KHz tick rate, and it is
not recommended to go over 1KHz. You can however trigger tasks from an
interrupt, and a link to the recommended way of doing that has already
been provided.
Normally you would use the pdMS_TO_TICKS() macro to convert milliseconds
into tick periods, but that won’t work if the tick rate is greater than
1KHz.
rclub123 wrote on Thursday, September 29, 2016:
Thank you for your valuable suggestions… i have 1 last question…
i have created 2 tasks like below
void vTask0(void *pvParameters)
TickType_t xNextWakeTime;
const TickType_t xFrequency = 1;
xNextWakeTime = xTaskGetTickCount();
while(1)
if (xSemaphoreTake(xGPIOmutex, (portTickType)10) == pdTRUE)
adc_val[0]=ADC_read();
xSemaphoreGive(xGPIOmutex);
vTaskDelayUntil(&xNextWakeTime, xFrequency);
printf("channel 0 = %d \n", adc_val[0]);
void vTask1(void *pvParameters)
const TickType_t xFrequency = 10;
while (1)
adc_val[1]=ADC1_read();
printf("channel 1 = %d \n", adc_val[1]);
if i set xFrequency=1 in task 1, the above code(both task 1 and task 2) will execute only once… if i put xFrequency=5 in task1 then both will work fine… what might be the problem why it is not working if set xFrequency=1?
rtel wrote on Thursday, September 29, 2016:
I would expect it to work with xFrequency set to 1. What happens if you
take out the call to printf()? Without printf() you might not be able
to tell if it is working or not, so you can replace the printf() with a
pin toggle that you can then view on a scope, or replace the printf()
with a simple variable increment so when you pause the debugger you can
view the variable’s value (use a different variable for each task and
ensure the variable is declared volatile).
I tried what you said… i took variable ‘a’ for task1 and ‘b’ for task1 i add these two variables to watch list… as per as my understanding of the code value of ‘b’ should be 10 multiple of ‘a’… i.e. if b=1 then ‘a’ should be 10, if b=2, ‘a’ should be 20… but in my case it is random… or may be “almost 5 multiple”(hope you understood)…
