For the next release, will you be able to suppress the type-punning warnings that arm-elf-gcc 4.1.2 throws? The GCC flag set being used is: -Wall -Wextra -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-align -Wsign-compare -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wunused
Will structures declarations and such be visible outside of FreeRTOS? I’m not interested in the instantiated data, but it would be nice to be able to do a sizeof (xheap) and others for sizing purposes. I definitely believe the actual FreeRTOS data should be private, the way you’re doing it now.
Will there be a call to determine if the scheduler is running? It would be nice to know if the scheduler has been not yet started, running (xSchedulerRunning), and suspended (uxSchedulerSuspended).
Do you have a set date for the release? I’d like to release an update of the demo package, but not before you release the latest FreeRTOS.
> is: -Wall -Wextra
> -Wsign-compare
> -Wunused
I only get the warning with optimisation strangely. I presumed it was because of the strict aliasing option, but you don’t have that in your list here.
> FreeRTOS? I’m
> to be able to
This can be on the list, but I’m not sure if it will get done this time around. Can you please add these to the feature request tracker (in SourceForge) so they stay visible.
Well, it was planned for this Monday or Tuesday, but with the discussions that have been going on here over the last day it may be delayed a little. I don’t want to delay it as missing this deadline will put it back probably about three weeks, so I will do my best to get it out on time.
