I am trying to do a basic server authentication from provided demo for windows simulator.
I tried with httpbin.org with certificate provided over here. It was working fine.
I tried with another web server e.g example 1, example 2
I exported these certificates as shown in the image below
and added in the header.
I also viewed some other forum post about MQTT auth TLS handshake failures and tried to with SNI 0 and 1 , but still I am facing Handshake error.
Also, I have enabled support for TLS1.3 in mbedtls_config.h
demo_config.h (9.1 KB)
mbedtls_config.h (145.4 KB)
Logs for simulator
The interface that will be opened is set by "configNETWORK_INTERFACE_TO_USE", which
should be defined in FreeRTOSConfig.h
Attempting to open interface number 2.
Successfully opened interface number 2.
vDHCPProcessEndPoint: enter 0
2 141 [IP-Task] DHCP-socket[11-41]: DHCP Socket Create
prvCreateDHCPSocket[11-41]: open, user count 1
3 141 [IP-Task] prvInitialiseDHCP: start after 250 ticks
vDHCP_RATimerReload: 250
4 141 [IP-Task] vDHCPProcessEndPoint: exit 1
[INFO] [HTTPDemo] [prvHTTPDemoTask:256] 5 143 [DemoTask] ---------STARTING DEMO---------
6 143 [DemoTask] [INFO] [HTTPDemo] [prvHTTPDemoTask:261] Waiting for the network link up event...
7 200 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 0.0.0.0
8 260 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
Network interface: dropped packet
9 391 [IP-Task] vDHCPProcessEndPoint: enter 1
vDHCPProcess: discover
10 391 [IP-Task] vDHCPProcessEndPoint: exit 2
Bounced back by WinPCAP interface: 00:11:11:11:11:41
11 420 [IP-Task] vDHCPProcessEndPoint: enter 2
vDHCPProcess: offer 10.25.10.41 for MAC address 11-41
12 420 [IP-Task] vDHCPProcess: reply 10.25.10.41
vDHCPProcessEndPoint: exit 3
13 460 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 0.0.0.0
14 460 [IP-Task] vDHCPProcessEndPoint: enter 3
15 460 [IP-Task] vDHCPProcess: acked 10.25.10.41
IP Address: 10.25.10.41
16 460 [IP-Task] Subnet Mask: 255.255.255.0
Gateway Address: 10.25.10.1
17 460 [IP-Task] DNS Server Address: 10.254.254.1
prvCloseDHCPSocket[11-41]: closed, user count 0
18 460 [IP-Task] vDHCP_RATimerReload: 129600000
vDHCPProcessEndPoint: exit 5
19 560 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
20 600 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
21 660 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
22 720 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
23 900 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
24 900 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
25 940 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
26 1143 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
27 1143 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 10.254.254.1
ARP 10.254.254.1 miss using 10.25.10.1
28 1143 [IP-Task] FreeRTOS_FindEndPointOnNetMask[11]: No match for 10.254.254.1
29 1320 [MAC_ISR] Network interface: dropped packet
30 1440 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
pxEasyFit: ARP 10.25.10.41 -> 10.25.10.1
31 1480 [IP-Task] ipARP_REPLY from 10.25.10.1 to 10.25.10.41 end-point 10.25.10.41
32 1640 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
33 1900 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
34 1960 [MAC_ISR] Network interface: dropped packet
35 2200 [MAC_ISR] Network interface: dropped packet
36 2300 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
EasyFit[dd86]: 0 0 0 ( fe80::5ef0:309e:963b:b8ed ->ff02::fb ) BAD
37 2360 [MAC_ISR] Network interface: dropped packet
pxEasyFit: ARP 10.25.10.20 -> 10.25.10.47
38 2400 [IP-Task] ipARP_REQUEST from 10.25.10.20 to 10.25.10.47 end-point 10.25.10.41
39 2660 [IP-Task] ipARP_REQUEST from 10.25.10.20 to 10.25.10.47 end-point 10.25.10.41
40 2720 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
41 2820 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
42 2880 [MAC_ISR] Network interface: dropped packet
43 3201 [IP-Task] ipARP_REQUEST from 10.25.10.20 to 10.25.10.47 end-point 10.25.10.41
44 3261 [MAC_ISR] Network interface: dropped packet
45 3401 [MAC_ISR] Network interface: dropped packet
46 3761 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
47 3821 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
48 3861 [MAC_ISR] Network interface: dropped packet
49 4121 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
50 4281 [MAC_ISR] Network interface: dropped packet
51 4381 [MAC_ISR] Network interface: dropped packet
52 4621 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::16 ) BAD
53 4621 [MAC_ISR] Network interface: dropped packet
54 4621 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
55 4641 [MAC_ISR] Network interface: dropped packet
EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::fb ) BAD
56 4641 [MAC_ISR] Network interface: dropped packet
57 4641 [MAC_ISR] Network interface: dropped packet
EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::1:3 ) BAD
58 4641 [MAC_ISR] Network interface: dropped packet
59 4781 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
60 4841 [MAC_ISR] Network interface: dropped packet
61 5041 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
62 5561 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
63 5801 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
EasyFit[dd86]: 0 0 0 ( fe80::ab4b:7df0:32a4:2c41 ->ff02::fb ) BAD
64 5861 [MAC_ISR] Network interface: dropped packet
65 6021 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
DNS_ReadReply returns -11
66 6143 [DemoTask] prvIncreaseDNS4Index: from 0 to 1
FreeRTOS_FindEndPointOnNetMask[4]: No match for 8.8.8.8
67 6143 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
pxEasyFit: ARP 10.25.10.41 -> 10.25.10.16
68 6221 [IP-Task] ipARP_REPLY from 10.25.10.16 to 10.25.10.41 end-point 10.25.10.41
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1800)
69 6221 [DemoTask] DNS[0xBD69]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 23641 to 159.89.140.122:443
70 6221 [DemoTask] Socket 23641 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
71 6221 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
prvSocketSetMSS: 1400 bytes for 159.89.140.122 port 443
72 6221 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
73 6221 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Connect[159.89.140.122:443]: next timeout 1: 3000 ms
74 6281 [IP-Task] MSS change 1400 -> 1343
Change mss 1400 => 1343
75 6281 [IP-Task] TCP: active 23641 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 23641 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
76 6281 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
77 6281 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
78 6306 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
79 6321 [IP-Task] MSS: sending 1343
pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
80 6381 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
81 6381 [MAC_ISR] Network interface: dropped packet
ipARP_REQUEST from 10.25.10.37 to 10.25.10.215 end-point 10.25.10.41
82 6381 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::fb ) BAD
83 6421 [MAC_ISR] Network interface: dropped packet
84 6421 [MAC_ISR] Network interface: dropped packet
85 6421 [MAC_ISR] Network interface: dropped packet
86 6421 [MAC_ISR] Network interface: dropped packet
87 6581 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 23641 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
88 6581 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
89 6592 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
90 6642 [IP-Task] Socket 23641 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 23641 to 159.89.140.122 port 443]: buffers 60 socks 0
91 6642 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
92 6642 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 1 out of maximum retry attempts 5.
93 6642 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
94 6642 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
95 6643 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1799)
96 6682 [DemoTask] DNS[0x2321]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 27320 to 159.89.140.122:443
97 6682 [DemoTask] Socket 27320 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
98 6682 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
99 6682 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
100 6682 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
101 6742 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
102 6742 [IP-Task] MSS change 1400 -> 1343
103 6742 [IP-Task] TCP: active 27320 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 27320 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
104 6742 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
105 6742 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
106 6765 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
107 6802 [IP-Task] MSS: sending 1343
108 6842 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
109 6902 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
110 6942 [MAC_ISR] Network interface: dropped packet
111 6942 [MAC_ISR] Network interface: dropped packet
112 6942 [MAC_ISR] Network interface: dropped packet
113 6942 [MAC_ISR] Network interface: dropped packet
EasyFit[dd86]: 0 0 0 ( fe80::8166:e699:8a0c:f59a ->ff02::1:2 ) BAD
114 7042 [MAC_ISR] Network interface: dropped packet
115 7042 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 27320 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
116 7042 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
117 7054 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
118 7102 [IP-Task] Socket 27320 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 27320 to 159.89.140.122 port 443]: buffers 60 socks 0
119 7102 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
120 7102 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 2 out of maximum retry attempts 5.
121 7102 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
122 7102 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
123 7102 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1798)
124 7162 [DemoTask] DNS[0xDDF6]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 23415 to 159.89.140.122:443
125 7162 [DemoTask] Socket 23415 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
126 7162 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
127 7162 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
128 7162 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
129 7202 [IP-Task] MSS change 1400 -> 1343
130 7202 [IP-Task] TCP: active 23415 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 23415 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
131 7202 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
132 7202 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
133 7227 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
134 7262 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
135 7302 [IP-Task] MSS: sending 1343
136 7522 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 23415 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
137 7522 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
138 7535 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
139 7582 [IP-Task] Socket 23415 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 23415 to 159.89.140.122 port 443]: buffers 60 socks 0
140 7582 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
141 7582 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 3 out of maximum retry attempts 5.
142 7582 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
143 7582 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
144 7582 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1797)
145 7622 [DemoTask] DNS[0x1E69]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 41550 to 159.89.140.122:443
146 7622 [DemoTask] Socket 41550 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
147 7622 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
148 7622 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
149 7622 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
150 7682 [IP-Task] MSS change 1400 -> 1343
151 7682 [IP-Task] TCP: active 41550 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 41550 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
152 7682 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
153 7682 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
154 7708 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
155 7722 [IP-Task] MSS: sending 1343
156 7942 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
157 7942 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
158 7982 [MAC_ISR] Network interface: dropped packet
159 7982 [MAC_ISR] Network interface: dropped packet
160 7982 [MAC_ISR] Network interface: dropped packet
161 7982 [MAC_ISR] Network interface: dropped packet
162 7982 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 41550 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
163 7982 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
164 7993 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
165 8022 [IP-Task] Socket 41550 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 41550 to 159.89.140.122 port 443]: buffers 60 socks 0
166 8022 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
167 8022 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 4 out of maximum retry attempts 5.
168 8022 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
169 8022 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
170 8023 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1796)
171 8082 [DemoTask] DNS[0x7135]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 26570 to 159.89.140.122:443
172 8082 [DemoTask] Socket 26570 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
173 8082 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
174 8082 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
175 8082 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
176 8142 [IP-Task] MSS change 1400 -> 1343
177 8142 [IP-Task] TCP: active 26570 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 26570 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
178 8142 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
179 8142 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
180 8167 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
181 8182 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
182 8242 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::7751:e897:a7da:c36d ->ff02::1:2 ) BAD
183 8242 [IP-Task] MSS: sending 1343
184 8442 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 26570 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
185 8442 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
186 8454 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
187 8502 [IP-Task] Socket 26570 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 26570 to 159.89.140.122 port 443]: buffers 60 socks 0
188 8502 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
189 8502 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 5 out of maximum retry attempts 5.
190 8502 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
191 8502 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
192 8502 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1795)
193 8562 [DemoTask] DNS[0x564C]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 3977 to 159.89.140.122:443
194 8562 [DemoTask] Socket 3977 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
195 8562 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
196 8562 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
197 8562 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
198 8622 [MAC_ISR] pxEasyFit: ARP 10.25.10.19 -> 10.25.10.7
ipARP_REQUEST from 10.25.10.19 to 10.25.10.7 end-point 10.25.10.41
199 8622 [IP-Task] MSS change 1400 -> 1343
200 8622 [IP-Task] TCP: active 3977 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 3977 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
201 8622 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
202 8622 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
203 8652 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
204 8722 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
MSS: sending 1343
205 8722 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
pxEasyFit: ARP 10.25.10.16 -> 10.25.10.41
206 8782 [IP-Task] ipARP_REQUEST from 10.25.10.16 to 10.25.10.41 end-point 10.25.10.41
207 8942 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 3977 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
208 8942 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
209 8953 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
210 8982 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
Socket 3977 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
211 8982 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
FreeRTOS_closesocket[0.0.0.0 port 3977 to 159.89.140.122 port 443]: buffers 60 socks 0
212 8982 [DemoTask] [ERROR] [HTTP] [connectToServerWithBackoffRetries:131] Connection to the server failed, all attempts exhausted.
213 8982 [DemoTask] [ERROR] [HTTPDemo] [prvHTTPDemoTask:295] Failed to connect to HTTP server mp8e5bc1c277a8e60f76.free.beeceptor.com.
214 8982 [DemoTask] [WARN] [HTTPDemo] [prvHTTPDemoTask:331] Demo iteration 1 failed. Retrying...
215 9082 [MAC_ISR] pxEasyFit: ARP 10.25.10.19 -> 10.25.10.7
216 9802 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
217 9842 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
218 9944 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
219 10044 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
220 10084 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::fb ) BAD
221 10084 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::fb ) BAD
222 10084 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::fb ) BAD
223 10084 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::fb ) BAD
224 10144 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
225 10244 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
226 10604 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
227 10704 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
228 11064 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
229 11064 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
230 11164 [MAC_ISR] pxEasyFit: ARP 10.25.10.20 -> 10.25.10.215
ipARP_REQUEST from 10.25.10.20 to 10.25.10.215 end-point 10.25.10.41
231 11424 [MAC_ISR] pxEasyFit: ARP 10.25.10.20 -> 10.25.10.215
232 11464 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
233 11564 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
234 11625 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
235 11665 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
236 11945 [MAC_ISR] pxEasyFit: ARP 10.25.10.20 -> 10.25.10.215
237 12085 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
238 12085 [MAC_ISR] Network interface: dropped packet
239 12145 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
240 12145 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
241 12505 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
242 12605 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
243 12665 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
244 12725 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::97c3:cbd5:b213:88c9 ->ff02::fb ) BAD
245 13185 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
246 13185 [MAC_ISR] Network interface: dropped packet
247 13225 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::97c3:cbd5:b213:88c9 ->ff02::fb ) BAD
248 13425 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::3bda:94ce:cd00:64d7 ->ff02::fb ) BAD
249 13525 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
250 13625 [MAC_ISR] pxEasyFit: ARP 10.25.10.7 -> 10.25.10.1
251 13625 [MAC_ISR] Network interface: dropped packet
ipARP_REQUEST from 10.25.10.7 to 10.25.10.1 end-point 10.25.10.41
252 13945 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::3bda:94ce:cd00:64d7 ->ff02::fb ) BAD
253 13982 [DemoTask] [INFO] [HTTPDemo] [prvHTTPDemoTask:256] ---------STARTING DEMO---------
254 13982 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
255 13982 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
256 13982 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1785)
257 14045 [DemoTask] DNS[0x2B86]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 16224 to 159.89.140.122:443
258 14045 [DemoTask] Socket 16224 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
259 14045 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
260 14045 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
261 14045 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
262 14085 [IP-Task] MSS change 1400 -> 1343
263 14085 [IP-Task] TCP: active 16224 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 16224 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
264 14085 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
265 14085 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
266 14110 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
267 14145 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
268 14145 [MAC_ISR] Network interface: dropped packet
269 14145 [IP-Task] MSS: sending 1343
270 14185 [MAC_ISR] Network interface: dropped packet
271 14185 [MAC_ISR] Network interface: dropped packet
272 14185 [MAC_ISR] Network interface: dropped packet
273 14185 [MAC_ISR] Network interface: dropped packet
274 14185 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
275 14405 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 16224 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
276 14405 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
277 14418 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
278 14445 [IP-Task] Socket 16224 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 16224 to 159.89.140.122 port 443]: buffers 60 socks 0
279 14445 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
280 14445 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 1 out of maximum retry attempts 5.
281 14445 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
282 14445 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
283 14446 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1784)
284 14505 [DemoTask] DNS[0xC880]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 60125 to 159.89.140.122:443
285 14505 [DemoTask] Socket 60125 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
286 14505 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
287 14505 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
288 14505 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
289 14545 [IP-Task] MSS change 1400 -> 1343
290 14545 [IP-Task] TCP: active 60125 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 60125 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
291 14545 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
292 14545 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
293 14571 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
294 14605 [IP-Task] MSS: sending 1343
295 14665 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
296 14865 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 60125 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
297 14865 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
298 14875 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
299 14905 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
300 14905 [IP-Task] Socket 60125 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 60125 to 159.89.140.122 port 443]: buffers 60 socks 0
301 14905 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
302 14905 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 2 out of maximum retry attempts 5.
303 14905 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
304 14905 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
305 14905 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
306 14965 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1783)
307 14965 [DemoTask] DNS[0x57E0]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 22686 to 159.89.140.122:443
308 14965 [DemoTask] Socket 22686 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
309 14965 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
310 14965 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
311 14965 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
312 15005 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
313 15005 [IP-Task] MSS change 1400 -> 1343
314 15005 [IP-Task] TCP: active 22686 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 22686 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
315 15005 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
316 15005 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
317 15031 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
318 15065 [IP-Task] MSS: sending 1343
319 15105 [MAC_ISR] Network interface: dropped packet
320 15165 [IP-Task] ipARP_REQUEST from 10.25.10.35 to 10.25.10.215 end-point 10.25.10.41
321 15205 [MAC_ISR] Network interface: dropped packet
322 15245 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
323 15305 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
324 15305 [IP-Task] Socket 22686 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
325 15305 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
326 15316 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
327 15345 [IP-Task] Socket 22686 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 22686 to 159.89.140.122 port 443]: buffers 60 socks 0
328 15345 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
329 15345 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 3 out of maximum retry attempts 5.
330 15345 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
331 15345 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
332 15345 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
333 15405 [MAC_ISR] Network interface: dropped packet
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1782)
334 15405 [DemoTask] DNS[0xEE65]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 19513 to 159.89.140.122:443
335 15405 [DemoTask] Socket 19513 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
336 15405 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
337 15405 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
338 15405 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
339 15445 [IP-Task] MSS change 1400 -> 1343
340 15445 [IP-Task] TCP: active 19513 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 19513 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
341 15445 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
342 15445 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
343 15472 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
344 15505 [IP-Task] MSS: sending 1343
345 15645 [MAC_ISR] Network interface: dropped packet
346 15745 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 19513 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
347 15745 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
348 15758 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
349 15805 [MAC_ISR] pxEasyFit: ARP 10.25.10.31 -> 10.25.10.215
Socket 19513 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
350 15805 [IP-Task] ipARP_REQUEST from 10.25.10.31 to 10.25.10.215 end-point 10.25.10.41
FreeRTOS_closesocket[0.0.0.0 port 19513 to 159.89.140.122 port 443]: buffers 60 socks 0
351 15805 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
352 15805 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 4 out of maximum retry attempts 5.
353 15805 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
354 15805 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
355 15806 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1781)
356 15865 [DemoTask] DNS[0x0C47]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 25391 to 159.89.140.122:443
357 15865 [DemoTask] Socket 25391 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
358 15865 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
359 15865 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
360 15865 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
361 15905 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
362 15905 [IP-Task] MSS change 1400 -> 1343
363 15905 [IP-Task] TCP: active 25391 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 25391 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
364 15905 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
365 15905 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
366 15931 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
367 16005 [IP-Task] MSS: sending 1343
368 16165 [MAC_ISR] Network interface: dropped packet
369 16205 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 25391 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
370 16205 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
371 16215 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
372 16265 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
Socket 25391 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
373 16267 [IP-Task] ipARP_REQUEST from 10.25.10.22 to 10.25.10.1 end-point 10.25.10.41
FreeRTOS_closesocket[0.0.0.0 port 25391 to 159.89.140.122 port 443]: buffers 60 socks 0
374 16267 [DemoTask] [WARN] [HTTP] [connectToServerWithBackoffRetries:121] Connection to the HTTP server failed. Retrying connection with backoff and jitter.
375 16267 [DemoTask] [INFO] [HTTP] [connectToServerWithBackoffRetries:124] Retry attempt 5 out of maximum retry attempts 5.
376 16267 [DemoTask] [INFO] [HTTPDemo] [prvConnectToServer:388] Establishing a TLS session to mp8e5bc1c277a8e60f76.free.beeceptor.com:443.
377 16267 [DemoTask] FreeRTOS_ProcessDNSCache: look-up: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 0)
378 16268 [IP-Task] ARP 8.8.8.8 hit using 10.25.10.1
FreeRTOS_ProcessDNSCache: add: 'mp8e5bc1c277a8e60f76.free.beeceptor.com' @ 159.89.140.122 (TTL 1780)
379 16305 [DemoTask] DNS[0x6A64]: The answer to 'mp8e5bc1c277a8e60f76.free.beeceptor.com' (159.89.140.122) will be stored
FreeRTOS_connect: 1999 to 159.89.140.122:443
380 16305 [DemoTask] Socket 1999 -> [159.89.140.122]:443 State eCLOSED->eCONNECT_SYN
381 16305 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
382 16305 [IP-Task] prvWinScaleFactor: uxRxWinSize 1 MSS 1400 Factor 0
383 16305 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
384 16365 [IP-Task] MSS change 1400 -> 1343
385 16365 [IP-Task] TCP: active 1999 => 122.140.89.159 port 443 set ESTAB (scaling 1)
Socket 1999 -> [159.89.140.122]:443 State eCONNECT_SYN->eESTABLISHED
386 16365 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
387 16365 [DemoTask] [INFO] [SocketsWrapper] [TCP_Sockets_Connect:189] Established TCP connection with mp8e5bc1c277a8e60f76.free.beeceptor.com.
388 16389 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
389 16425 [IP-Task] MSS: sending 1343
390 16465 [IP-Task] ipARP_REQUEST from 10.25.10.20 to 10.25.10.215 end-point 10.25.10.41
391 16665 [IP-Task] ARP 159.89.140.122 hit using 10.25.10.1
Socket 1999 -> [159.89.140.122]:443 State eESTABLISHED->eLAST_ACK
392 16665 [IP-Task] FreeRTOS_FindEndPointOnNetMask[4]: No match for 159.89.140.122
393 16677 [DemoTask] [ERROR] [MbedtlsTransport] [tlsHandshake:606] Failed to perform TLS handshake: mbedTLSError= SSL - A fatal alert message was received from our peer : <No-Low-Level-Code>.
394 16725 [IP-Task] Socket 1999 -> [159.89.140.122]:443 State eLAST_ACK->eCLOSE_WAIT
FreeRTOS_closesocket[0.0.0.0 port 1999 to 159.89.140.122 port 443]: buffers 60 socks 0
395 16725 [DemoTask] [ERROR] [HTTP] [connectToServerWithBackoffRetries:131] Connection to the server failed, all attempts exhausted.
396 16725 [DemoTask] [ERROR] [HTTPDemo] [prvHTTPDemoTask:295] Failed to connect to HTTP server mp8e5bc1c277a8e60f76.free.beeceptor.com.
397 16725 [DemoTask] [WARN] [HTTPDemo] [prvHTTPDemoTask:331] Demo iteration 2 failed. Retrying...
398 16785 [MAC_ISR] pxEasyFit: ARP 10.25.10.20 -> 10.25.10.215
399 16825 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
400 16885 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::34da:241:b2f1:fd6e ->ff02::fb ) BAD
401 16945 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
402 17205 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
403 17245 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
404 17305 [MAC_ISR] pxEasyFit: ARP 10.25.10.20 -> 10.25.10.215
405 17365 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
406 17365 [MAC_ISR] Network interface: dropped packet
407 17685 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
408 17785 [MAC_ISR] pxEasyFit: ARP 10.25.10.37 -> 10.25.10.215
409 17846 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::75c6:11c2:76b4:d4fe ->ff02::fb ) BAD
410 17986 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::c25f:61bb:a6b6:6871 ->ff02::c ) BAD
411 18206 [MAC_ISR] pxEasyFit: ARP 10.25.10.35 -> 10.25.10.215
412 18366 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::75c6:11c2:76b4:d4fe ->ff02::fb ) BAD
413 18406 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
414 19346 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
415 19446 [MAC_ISR] pxEasyFit: ARP 10.25.10.22 -> 10.25.10.1
416 19826 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
417 20346 [MAC_ISR] EasyFit[dd86]: 0 0 0 ( fe80::1328:a12f:19d:fa5c ->ff02::1:ff39:c898 ) BAD
