Say I have a task which uses preallocated memory. This memory will never be occupied by any other object during the program duration. Can I then assume that all references and pointers to objects within that buffer resolve correctly even after the underlying task has been deleted?
Compare the following: Here I create a task which resides on statically allocated memory. It spawns another (dynamically allocated) task that receives a reference to a stack local variable of the static task. Can it continue to use it without restrictions (assuming that the buffer is not again occupied by another statically allocated task…)?
#include <stdio.h>
#include <iostream>
#include "freertos/FreeRTOS.h"
#include "freertos/queue.h"
#include "freertos/task.h"
#include <array>
#include <memory>
StackType_t stack_buffer[1024];
StaticTask_t task_buffer;
void some_other_task(void* param)
int& a = *static_cast<int*>(param);
std::cout << "before: " << a << std::endl;
vTaskDelay(100);
a = 3;
std::cout << "after: " << a << std::endl;
vTaskDelay(portMAX_DELAY);
void some_task(void* param)
int a = 5;
xTaskCreate(some_other_task, "other task", 1024, &a, 10, NULL);
vTaskDelete( NULL );
extern "C" void app_main(void)
// TaskHandle_t xHandle;
xTaskCreateStatic(some_task, "task", 1024, NULL, 10, stack_buffer, &task_buffer);
