After vTaskDelete, created objects gone too?
jirachi2 wrote on Tuesday, May 20, 2014:
Will objects created in a task, be gone too when I delete this task with vTaskDelete(NULL)?
rtel wrote on Tuesday, May 20, 2014:
From http://www.freertos.org/a00126.html “Memory allocated by the task code is not automatically freed, and should be freed before the task is deleted.” so no - only the memory allocated to the task by the kernel (the TCB and stack) are freed. If you application code allocates any other memory or objects it must delete them.
Thanks!!
Another question, regarding C++. For example: I have a Foo object. That Foo object makes 3 Bar objects. If I delete the Foo object, will the Bar objects be gone too?
I don’t think that question is related to FreeRTOS.
Correct, but could you please answer? You are so superfast in responsing, and I’m sure you know the answer. In the future I won’t ask other than FreeRTOS related things.
Sorry but this forum is specifically for FreeRTOS questions, and to remain a valuable resource to people using FreeRTOS must remain so and not become a chatty general programming forum.
There are lots of forums where you can post your C++ questions.
