configASSERT failure happens when an ACK message is received out of sequence
Greetings,
I encountered another bug while developing a Fleet Provisioning (FP) application which runs on the Renesas RX65N MCU.
In rare occassions (~1 out of 500 attempts), the following ASSERTION failure (or similar) occurs.
ASSERTION FAILED: globalSubscribePacketIdentifier == usPacketIdentifier FILE C:/ws/iot-reference-rx/Demos/common/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_h
(Note: The ASSERTION failure may also happen with globalUnsubscribePacketIdentifier == usPacketIdentifier)
I referred the reference code provided in this repo: FreeRTOS-Plus/Demo/../../mqtt_pkcs11_demo_helpers.c
This is my baseline code where I encountered the issue: mqtt_pkcs11_demo_helpers.c
After investigation, I found that the ASSERTION fails when the ACK packet is received out of sequence, maybe due to timing issue or network jitter.
(i.e: Device sends an Unsubscribe command, but received a prior SUBACK packet instead)
Request
  1. I believe the mqtt-agent is asynchronous, it does not wait for ACK before executing the next command.
    Based on this logic, I decided to remove the 2 failing configASSERT checks.
    →Is this acceptable?
  2. Additionally, I implemented a logic to return error in case no packet is received/processed within the timeout period.
    →Does this align with the original design policy?
I attached my modified code for reference: mqtt_pkcs11_demo_helpers.c (51.9 KB)
Thank you.
That should not be a problem because globalSubscribePacketIdentifier and globalUnsubscribePacketIdentifier are different? Or are you getting delayed SUBACKs?
@aggarg: Yes, I believe so. It’s either delayed or out-of-sequence.
The demo code that you linked does not use MQTT Agent. It uses MQTT instead: FreeRTOS/FreeRTOS-Plus/Demo/AWS/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_helpers.c at main · FreeRTOS/FreeRTOS · GitHub. The sequence is:
  1. Get a packet ID and store it in globalSubscribePacketIdentifier: FreeRTOS/FreeRTOS-Plus/Demo/AWS/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_helpers.c at main · FreeRTOS/FreeRTOS · GitHub.
  2. Send MQTT subscribe request: FreeRTOS/FreeRTOS-Plus/Demo/AWS/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_helpers.c at main · FreeRTOS/FreeRTOS · GitHub.
  3. Wait for ACK: FreeRTOS/FreeRTOS-Plus/Demo/AWS/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_helpers.c at main · FreeRTOS/FreeRTOS · GitHub.
Is it possible that you are not waiting long enough to get the ACK and proceeding with further operations? You can try increasing mqttexamplePROCESS_LOOP_TIMEOUT_MS: FreeRTOS/FreeRTOS-Plus/Demo/AWS/Mqtt_Demo_Helpers/mqtt_pkcs11_demo_helpers.c at main · FreeRTOS/FreeRTOS · GitHub.
@aggarg: Sorry for the late response.
Noted on your suggestion, that seems to be the most straightforward solution.
As mentioned in my post, this error very rarely happens.
I suppose we could try with a longer timeout period and re-test whether it helps with the issue.
Meanwhile, I’d still like to confirm the point below:
This process seems to be asynchronous (i.e: it does not wait for ACK before executing the next command.
In that case, is it acceptable if I were to remove the 2 failing configASSERT checks?
This is demo code and you are free to modify it as per your needs. The thing that you should verify is that the code is not written in such a way that ACK for one message may be mistaken for some other. As long as it is not the case, it should be fine.
@aggarg : Thanks for the advice, I have no further questions.
I’ll mark you comment re: increasing timeout as the solution and close this ticket.
Thank you!
