Bonjour j’ai utilisé le projet demo win32_MSCV et lors de manipulation de ce projet j’ai utilisé vTaskList j’ai eu un problème de compilation (Error C1083 Cannot open include file: ‘trcRecorder.h’: No such file or director) malgrés que le fichier trcRecorder.h existe.
Which project are you trying to build? Or did you create a project
yourself?
The trace recorder code is only included in a few projects that we
distribute, they should build, but of course there is always a chance
that we missed something.
It is not clear what you are doing, but from your posts so far it sounds like you have created a project using the Windows simulator, and that project is having a problem related to the trace recorder. I am assuming that if you created the project yourself that you have not added the trace recorder code and that is the cause of your issue.
If you use the Win32 project in the FreeRTOS download then you need to remove any calls to the trace functionality. For example:
