trcRecorder.h: No such file or directory when using CMakeLists.txt
I wanted to use CMakeLists.txt to configure a couple of things to generate a new Makefile for compiling the Posix GCC blinky demo application.
These are the steps I am taking to achieve this -
cd FreeRTOS/Demo/Posix_GCC
mkdir build
cd build
cmake ..
make
This results in make failing with -
FreeRTOS/Demo/Posix_GCC/./FreeRTOSConfig.h:157:14: fatal error: trcRecorder.h: No such file or directory
  157 |     #include "trcRecorder.h"
Do I have to add any specific includes before I run cmake for this to work?
Hi @PwnVerse
Welcome to the FreeRTOS Community Forums. Thank you for reporting the issue.
I was able to reproduce the issue you are facing .
Can you add and change the following lines to your CMakeLists.txt
target_include_directories( freertos_config
    INTERFACE
        ./Trace_Recorder_Configuration
        ${FREERTOS_PLUS_TRACE_PATH}/include
        ${FREERTOS_PLUS_TRACE_PATH}/kernelports/FreeRTOS/include
file( GLOB FREERTOS_PLUS_TRACE_SOURCES ${FREERTOS_PLUS_TRACE_PATH}/*.c ${FREERTOS_PLUS_TRACE_PATH}/kernelports/FreeRTOS/trcKernelPort.c )
This PR addresses these changes.
Hi @karahulx ,
Thanks alot for the quick response. This PR fixes the issue I was facing.
Regards
Hi @PwnVerse
Thanks for reporting back.
