Dear all,
I tried to use CMake to build the Amazon FreeRTOS Demo for PC Simulator (as a starting point).
I followed the instructions here: Using CMake with FreeRTOS - FreeRTOS.
The source code is downloaded from Github: Release Version 202002.00 · aws/amazon-freertos · GitHub (tag 202002.00).
I used CMake 3.16.0, GUI, and MinGW.
Firstly, I encountered problem about “Unknown CMake command “afr_set_board_metadata””.
I managed to include all .cmake files to \vendors\pc\boards\windows\CMakeLists.txt.
include(C:/Workspace/amazon-freertos-experiment/tools/cmake/afr.cmake OPTIONAL)
include(${AFR_ROOT_DIR}/vendors/pc/manifest.cmake OPTIONAL)
include(${AFR_ROOT_DIR}/tools/cmake/afr_board_paths.cmake OPTIONAL)
include(${AFR_ROOT_DIR}/tools/cmake/afr_metadata.cmake OPTIONAL)
include(${AFR_ROOT_DIR}/tools/cmake/afr_module.cmake OPTIONAL)
Then the configuration continued, though there were some warnings.
CMake Warning at C:/Workspace/amazon-freertos-experiment/tools/cmake/afr_utils.cmake:55 (message):
Item
C:/Workspace/amazon-freertos-experiment/libraries/freertos_plus/aws/ota/test/aws_test_ota_cbor.c
already in list AFR_MODULE_test_ota_SOURCES_INTERFACE.
Call Stack (most recent call first):
C:/Workspace/amazon-freertos-experiment/tools/cmake/afr_module.cmake:169 (afr_cache_append)
C:/Workspace/amazon-freertos-experiment/tools/cmake/afr_module.cmake:177 (__afr_module_prop)
CMakeLists.txt:158 (afr_module_sources)CMake Warning at C:/Workspace/amazon-freertos-experiment/tools/cmake/afr_utils.cmake:55 (message):
Item
already in list AFR_MODULE_test_ota_SOURCES_ALL.
C:/Workspace/amazon-freertos-experiment/tools/cmake/afr_module.cmake:170 (afr_cache_append)
However, when I generated CMake files, it said “target was not found” for the portable targets such as freertos_plus_tcp, dev_mode_key_provisioning, utils…
These targets were already configured in CMakeLists.txt.
FreeRTOS Plus TCP
afr_mcu_port(freertos_plus_tcp)
target_sources(
AFR::freertos_plus_tcp::mcu_port
INTERFACE
“${AFR_MODULES_FREERTOS_PLUS_DIR}/standard/freertos_plus_tcp/source/portable/BufferManagement/BufferAllocation_2.c”
“${AFR_MODULES_FREERTOS_PLUS_DIR}/standard/freertos_plus_tcp/source/portable/NetworkInterface/WinPCap/NetworkInterface.c”
target_include_directories(
INTERFACE
“${AFR_MODULES_FREERTOS_PLUS_DIR}/standard/freertos_plus_tcp/source/portable/Compiler/MSVC”
target_link_libraries(
INTERFACE 3rdparty::win_pcap
Could anyone support me with a clue?
