Hi I want to change one of my deferred interrupt handlers from using a binary semaphore to taskNotify.
Is this the correct way to do it.
Using A semaphore:
if(HAL_SPI_TransmitReceive_DMA_rjg(&hspi2,
wiFiDataOut,
wiFiDataIn,
2U,
4U,
SPI_IT_EOT,
0xF0000005) != HAL_OK)
return WIFI_SPI_DRIVER_ERROR;
/* Wait for Ready state from WiFi * then check that it is Not ready */
if (xSemaphoreTake(wiFiReadySemHandle, (uint32_t)WIFI_CMD_TIME0UT) == pdFAIL)
return WIFI_SPI_TIMEOUT;
* @brief This function handles EXTI line[9:5] interrupts.
USE_ITCM void EXTI9_5_IRQHandler(void)
#if(CHK_LINE_IRQ_5 == 1)
if (__HAL_GPIO_EXTI_GET_IT(GPIO_PIN_5) != 0x00U)
/* DataReady Pin Rising */
__HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_5);
wiFiRdyState = true;
xSemaphoreGiveFromISR(wiFiReadySemHandle, &xHigherPriorityTaskWoken);
return;
Using Task Notify
wiFiDataOut,
wiFiDataIn,
2U,
4U,
SPI_IT_EOT,
if(!ulTaskNotifyTake(pdTRUE, (uint32_t)WIFI_CMD_TIME0UT))
vTaskNotifyGiveFromISR(wiFiTskHandle, &xHigherPriorityTaskWoken);
return;
I created a test program to try this out and started getting the occasional hard fault. So I thought maybe I was doing something wrong.
Regards
Rob
