jon_newcomb wrote on Tuesday, April 27, 2010:
I’m having one of those days where I’m missing the blinding obvious…
Using FreeRTOS V5.3.0, IAR 5.41.2, JLink, AT91SAM7S256
We have lots of comms on a singe SPI port. I thought it sensible to convert my (old and working I hope) binary
semaphore to a (new and improved) mutex.
I have a global declaration…
static xSemaphoreHandle semaphore_spi_guard;
Simple… change the line where it is initialised…
from
vSemaphoreCreateBinary (semaphore_spi_guard
to
semaphore_spi_guard = xSemaphoreCreateMutex(
As described in
http://www.freertos.org/a00121.html
http://www.freertos.org/CreateMutex.html
It compiles…
#define configUSE_MUTEXES 1 in FreeRTOSConfig.h
is all present and correct.
The help says…
“Mutexes created using this macro can be accessed using the xSemaphoreTake() and xSemaphoreGive() macros”
Great… I need not alter any of my code because this is the way I give and take my (old) binary SPI semaphore.
Reality was different…
I was disappointed to find every give or take of the mutex fails… time to start investigating…
I put breakpoints in a few different locations…
This is when started to really scratch my head and get confused…
in
xQueueHandle xQueueCreateMutex( void
The following values are end up as follows:
pxNewQueue->pcWriteTo = NULL;
pxNewQueue->pcReadFrom = NULL;
… OK, so unlike a queue, we don’t set these to the ‘head’ of a queue… So far so good.
Then every time we come to give or take the mutex I arrive at xQueueGenericSend or xQueueGenericReceive.
The very first few lines perform a check that always fails - and I cant work out why it does the check and how it can pass…
This check is…
if (!pxQueue || !pxQueue->pcHead) // extended check for valid Queue
return errQUEUE_UNDEF;
Well of course it fails with
errQUEUE_UNDEF
I get back to my give / take mutex having don’t nothing and returning a fail…
Please help… I’m very confused!
Thanks,
Jon Newcomb
