Hello, i’m newbie in FreeRTOS. There are ATMEL Studio 6.2 , core FRTOS 8.2.3, board based on ATSAM3S4A (not dev board) . I create new project , then added frm ASF Wizard freertos-spi(UART,TWI) interface layer(service) , replace a core 7.3.0 (wich added automatically ) with FRTOS 8.2.3, and for the first i make up only 1 task wich using uxTaskGetNumberOfTasks, vTaskList and output info to UART0, it’s work fine, then i add SPI func. - freertos_spi_write_packet ,it became crashing in xQueueGiveFromISR func. configASSERT( !( ( pxQueue->uxQueueType == queueQUEUE_IS_MUTEX ) && ( pxQueue->pxMutexHolder != NULL ) ) );
FreeRTOSconfig: http://textuploader.com/5u50n
simpl. CODE : http://textuploader.com/5u5r6
STACK: http://postimg.org/image/o0znwes4v/
This is due to a change in the way mutexes can be used. Try updating the ASF code so it creates a binary semaphore (xSemaphoreCreateBinary()) instead of a mutex (xSemaphoreCreateMutex()).
Ok , i change in 2 places to xSemaphoreCreateBinary(), but now func freertos_spi_write_packet return ERR_TIMEOUT(-3) in
freertos_peripheral_control.c
freertos_obtain_peripheral_access_mutex(freertos_dma_event_control_t *dma_event_control,portTickType *max_block_time_ticks)
{status_code_t return_value = STATUS_OK;
xTimeOutType time_out_definition;
if (dma_event_control->peripheral_access_mutex != NULL) {
/* Remember the time on entry. */
vTaskSetTimeOutState(&time_out_definition);
/* Wait to get exclusive access to the peripheral. */
if(xSemaphoreTake(dma_event_control->peripheral_access_mutex,*max_block_time_ticks) == pdFAIL) {
return_value = ERR_TIMEOUT; <-- COMING HERE
} else {/* Adjust the time out value in case the task had to block to wait for the semaphore. */
if (xTaskCheckForTimeOut(&time_out_definition,max_block_time_ticks) == pdTRUE) {*max_block_time_ticks = 0;}
}return return_value;}
The same project with FREERTOS 7.3.0 Library Work fine - return Status_OK(0)
