emike91 wrote on Monday, November 13, 2017:
hi everyone
I´m using the TM4c123 cortex m4 of TI and i’m trying to use the interrupts in FreeRTOS… here is the situation
I’ve two tasks running, the Task 1 is blocking after attempting to get a binary semaphore(this task has the higher priority) then the Task 2 is running a simple for loop, waiting for an interrupt(the interrupt is the Rx of the UART0) then in the ISR(UARTIntHandler) call the xSemaphoreGiveFromISR and then the portYIELD_FROM_ISR and here comes the problem because i’m expecting the running task will be the Task 1 because of the call to give the semaphore, but the Task 2 is actually running here is the simplified code also i put FreeRTOSconfig.h
void
ConfigureUART(void)
// Configure GPIO Pins for UART mode.
// Enable the GPIO Peripheral used by the UART.
ROM_IntPrioritySet(INT_UART0, 0xA3 );//Here im setting the interrupt priority
portDISABLE_INTERRUPTS();
UARTIntDisable(INT_UART0, UART_INT_TX | UART_INT_RI);
ROM_IntEnable(INT_UART0);
ROM_UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
void
vTask1 (void *pvParamaters)
while(1)
xSemaphoreTake( xBinarySemaphore, portMAX_DELAY ); //blocking the task
ROM_UARTCharGetNonBlocking(UART0_BASE)...;
void
vTask2 (void *pvParamaters)
while(1)
for ( u1 = 0; u1 < mainDELAY_LOOP_COUNT; u1++ ){}
void
UARTIntHandler(void)
xSemaphoreGiveFromISR( xBinarySemaphore, &xHigherPriorityTaskWoken );
ROM_UARTIntClear(INT_UART0, UART_INT_RX | UART_INT_RT);
if( xHigherPriorityTaskWoken )
portYIELD_FROM_ISR( xHigherPriorityTaskWoken );//After this, the context switch to Task 1 never happens
int
main(void)
ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_XTAL_16MHZ |SYSCTL_OSC_MAIN);
ConfigureUART();
xBinarySemaphore = xSemaphoreCreateBinary();
xTaskCreate( vTask1, "Task 1", 100, NULL, 2, NULL );
xTaskCreate( vTask2, "Task 2", 100, NULL, 1, NULL );
vTaskStartScheduler();
while(1)
FreeRTOSConfig.h
#define configUSE_TIME_SLICING 1
#define configMAX_PRIORITIES ( 5 )
#define configIDLE_SHOULD_YIELD 0
#define configUSE_16_BIT_TICKS 0 /* Only for 8 and 16-bit hardware. */
/* Constants that describe the hardware and memory usage. */
#define configCPU_CLOCK_HZ ( ( unsigned long ) 16000000 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 200 )
#define configMAX_TASK_NAME_LEN ( 12 )
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 20240 ) )
/* Constants that build features in or out. */
#define configUSE_MUTEXES 1
#define configUSE_TICKLESS_IDLE 0
#define configUSE_APPLICATION_TASK_TAG 0
#define configUSE_NEWLIB_REENTRANT 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_QUEUE_SETS 0
#define configUSE_TASK_NOTIFICATIONS 1
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 0
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_eTaskGetState 1
#define INCLUDE_xTaskResumeFromISR 0
#define INCLUDE_xTaskGetCurrentTaskHandle 1
#define INCLUDE_xTaskGetSchedulerState 0
#define INCLUDE_xSemaphoreGetMutexHolder 0
#define INCLUDE_xTimerPendFunctionCall 1
/* I'm not understanding the following 2 Macros but i saw this in a demo */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0x07
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Here i set the Kernel interrupt level and the priority level fromISR function calls */
#define configKERNEL_INTERRUPT_PRIORITY ( 7 << 5 ) /* Priority 7, or 0xE0 */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( 5 << 5 ) /* Priority 5, or 0xA0 */
i will appreciate any help or clue to get the code running thanks in advance :)))))
P.S: If anyone knows another technique to deferred an Interrupt in order to receive data from Uart I would appreciate it very much.
