sam-system wrote on Tuesday, May 13, 2008:
I have been trying to get FreeRTOS 5.0 running on a dvk90can1 evaluation board using WinAVR’s c++ compiler.
I’m using the port from Dr. Klaus Schaefer and trying out the his Can Driver and the following example.
http://kschaefer.eit.h-da.de/ATMEL/CAN/index.html
I have changed a few type casts in order to compile using avr-g++. But as you can see out of the below listing. The linking fails in the end. Some references to Queue.c break.
If I compile the same code using avr-gcc the linking is okay and the example runs fine on the board.
If I loose the dependences to queue.c in the example (only use the task system of FreeRTOS) the g++ compiled code runs fine.
I’m new to FreeRTOS and WinAVR. I have been looking into the FreeRTOS code and I can’t figure out why these references to queue.c break when compiling with g++. The compiler don’t report any errors before the linking is done.
Can someone please help me?
Build started 13.5.2008 at 07:44:11
avr-g++.exe -I"C:\Files\Data\AvrStudio\FreeRTOS\Projects\CanDriver\…\…\Source\include" -I"C:\Files\Data\AvrStudio\FreeRTOS\Projects\CanDriver\." -mmcu=at90can128 -Wall -gdwarf-2 -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -DGCC
_at90can128 -MD -MP -MT main.o -MF dep/main.o.d -c …/main.c
_at90can128 -MD -MP -MT can.o -MF dep/can.o.d -c …/can.c
_at90can128 -MD -MP -MT frtos_can.o -MF dep/frtos_can.o.d -c …/frtos_can.c
_at90can128 -MD -MP -MT tasks.o -MF dep/tasks.o.d -c …/…/…/Source/tasks.c
_at90can128 -MD -MP -MT queue.o -MF dep/queue.o.d -c …/…/…/Source/queue.c
_at90can128 -MD -MP -MT list.o -MF dep/list.o.d -c …/…/…/Source/list.c
_at90can128 -MD -MP -MT heap_1.o -MF dep/heap_1.o.d -c …/…/…/Source/portable/MemMang/heap_1.c
_at90can128 -MD -MP -MT port.o -MF dep/port.o.d -c …/…/…/Source/portable/GCC/AT90CAN128/port.c
_at90can128 -MD -MP -MT croutine.o -MF dep/croutine.o.d -c …/…/…/Source/croutine.c
avr-g++.exe -mmcu=at90can128 -Wl,-Map=CanDriver.map main.o can.o frtos_can.o tasks.o queue.o list.o heap_1.o port.o croutine.o -o CanDriver.elf
main.o: In function `receive_function’:
C:\Files\Data\AvrStudio\FreeRTOS\Projects\CanDriver\default/…/main.c:113: undefined reference to `xQueueGenericReceive’
frtos_can.o: In function `xCANQueueCreate’:
C:\Files\Data\AvrStudio\FreeRTOS\Projects\CanDriver\default/…/frtos_can.c:35: undefined reference to `xQueueCreate’
frtos_can.o: In function `CAN_callback(CAN_packet*, unsigned char)’:
C:\Files\Data\AvrStudio\FreeRTOS\Projects\CanDriver\default/…/frtos_can.c:27: undefined reference to `xQueueGenericSendFromISR’
make: *** [CanDriver.elf] Error 1
Build failed with 3 errors and 0 warnings…
