Please discuss a change in queue.c
nobody wrote on Monday, February 14, 2005:
Hi everybody,
I’m preparing a port to the C167 microcontroller (Infineon) to be published here. Now I encountered the following problem with the Keil IDE.
As I use the EC++ - Compiler supplied in the actual version of Keil’s IDE there’s a problem in queue.c. The line
<code>
typedef xQUEUE * xQueueHandle;
</code>
makes a different definition as given in queue.h
<code>
typedef void * xQueueHandle;
</code>
This is used to hide the xQUEUE-structure from the user. So far so good. The EC++ - Compiler now tries to find a overloaded function with the queue.h - definition. In queue.c there’s only xQUEUE definition. A linker-error (unresolved symbol) is the result.
My suggestion : Let’s change the definition of xQueueHandle in queue.c to void * too. When one does this, almost any occurence of the variable “pxQueue” in queue.c has to be changed to “((xQUEUE *)pxQueue)”.
I did this and it solved all problems with queue.c and queue.h. Please discuss this suggestion. I offer you my version of the v2.6.0 queue.c with this changes (~50 items to change !).
Thanks, Daniel Braun
eMail : Guru79@web.de
I presume this is a problem because you are using a C++ compiler rather than a C compiler.
Is it possible to designate the source files as C files with
extern "C"
around all the code in the file?  Alternatively is there a way from the project file to request that these particular files should be compiled as C files?
rtel wrote on Monday, February 14, 2005:
I am not surprised this is a problem with a C++ compiler.  In fact, I am surprised that none of the C compiler used have complained so far.
Do you find the same problem with the pxCurrentTCB variable?  This is defined both as tskTCB* and void* within the tasks.c and port.c files respectively.
As you say, this will require a lot of changes and probably effects the semaphore macros also.  There are two issues:
1) Readability.  There is a lot of casting already.  This is necessitated by the number of compilers used - each likes things slightly different.  More casting will reduce readability, BUT a #define could be used to prevent this.  eg
#define QUEUE ( ( xQUEUE *)pxQueue)
then just replace the pxQueue’s within the function bodies with QUEUE.
2) As just mentioned, each compiler likes things a little differently.  I would have to make sure that any changes are accepted by all the compilers.
Can the compiler be made to compiler files with a .c extension as C files, rather than C++?
Hi again,
1. if all C-functions defined so far have to be declared as extern C {…} one has to change the header queue.h (and others)
2. my proposal for casting should not affect other compilers - it should be possible to compile it with any C/C++ - Compiler.
3. I think Richard’s method (1) can enhance readability to a level comparable to today’s code.
4. I have now tested the modified queue.c (with standard queue.h) and found no problems.
Do you want the code to test it - where should I send it to ?
Regards, Daniel.
Hi Daniel,
Can you send it to the email address listed on the FreeRTOS.org site "contacts" page.  I will check it out with the other compilers.
