I have found a bug in the following function (from the “list.c” file in the Kernel):
void vListInsertEnd(List_t * const pxList, ListItem_t * const pxNewListItem)
ListItem_t * const pxIndex = pxList->pxIndex;
/* Integrity checks not used, code removed. */
/* Insert a new list item into pxList, but rather than sort the list,
make the new list item the last item to be removed by a call to
listGET_OWNER_OF_NEXT_ENTRY(). */
pxNewListItem->pxNext = pxIndex;
pxNewListItem->pxPrevious = pxIndex->pxPrevious;
/* Only used during decision coverage testing. */
mtCOVERAGE_TEST_DELAY();
pxIndex->pxPrevious->pxNext = pxNewListItem;
pxIndex->pxPrevious = pxNewListItem;
/* Remember which list the item is in. */
pxNewListItem->pvContainer = (void *) pxList;
(pxList->uxNumberOfItems)++;
/* BUG FOUND */
/* The documentation for this function mentions: "Placing */
/* an item in a list using vListInsertEnd(..) effectively */
/* places the item in the list position pointed to by pvIndex." */
/* I believe there are two bugs here: */
/* (1) The correct field name is not "pvIndex" but "pxIndex" */
/* (that's a documentation bug, so not really a big deal) */
/* (2) The pxList->pxIndex does not point to the NewListItem! */
/* The following code line was forgotten: */
pxList->pxIndex = pxNewListItem;
I understand your point that the comments in the code are no longer correct, but it is otherwise not clear to me - have you found something in the code that could either potentially mis-behave or potentially crash? If so, please state clearly what it is so it can be assessed.
By mis-behave I mean result in an incorrect task being selected, or other such incorrect behaviour?
Thank you very much for your quick reply
No, I did not see a misbehaviour. But I just figured out that the documentation mentions:
/* The "pxIndex" from the List_t will point to the newly inserted ListItem_t , such that every other item within the list will be returned by listGET_OWNER_OF_NEXT_ENTRY(..) before the pxIndex parameter again points to the item being inserted. */
Indeed, when you call the macro “listGET_OWNER_OF_NEXT_ENTRY(…)”, the pxIndex parameter from the list gets incremented first, such that it points to the “next entry” from which the owner is returned. So the documentation above makes perfectly sense.
Unfortunately, the documentation doesn’t correspond with the actual behaviour of the “vListInsertEnd(…)” function. This is because the following code line is forgotten (or at least, it looks to me like the developer forgot this line of code to update the pxIndex):
That’s all
One more question: I noticed that some parts of the documentation mention the List_t to be in descending order, whereas other parts of the documentation state that it’s ascending order. So I’m a bit confused.
From the function:
