I have enabled OTA on LTE based solution and I am able to perform MQTT messaging with AWS.
I am also able to perfom the OTA , but for only lesser amount of size binaries.
I tried performing OTA for 11.5KB size LED blink binary and it worked well.
When i tried to perform OTA for Larger size binaries i.e of 236.3KB it downloads some 1024 size blocks i.e 55 blocks of 1024 size and then i received below error
[ERROR][[INFO ][MNET][lu] MQTT][lu] (MQTT Error -1005 while sending on 0x2000acdata.18) MQTT PUBLISH operation queued.
[prvRequestFileBlock_Mqtt] OK: $aws/things/LTE_Thing/streams/AFR_OTA-2ca24077-3
I believe this i received this from IotNetworkAfr_Send() in iot_netowk_freertos.c file’s
IotLogError( "Error %ld while sending data.", ( long int ) socketStatus );
After this it does not download in any trials and ultimately stops.
Below are the more logs for information.
[ERROR][[INFO ][MNET][lu] ErQTT][lu] (MQror -1005 whTT connectiile sending on 0x2000acdata.18) MQTT PUBLISH operation queued.[prvRequestFileBlock_Mqtt] OK: $aws/things/LTE_Thing/streams/AFR_OTA-2ca24077-3
ffa-46e8-9bfa-6783fa[prvOTAAgentTask] Called handler. Current State [WaitingForFileBlock] Event [RequestTimer] New stat[INFO ][DEMO][lu] State: WaitingForFileBlock Received: 17 Queued: 0 Processed: 0
Dropped: 0
[INFO ][DEMO][lu] State: WaitingForFileBlock Received: 17 Queued: 0 Processed: 0 Dropped: 0
Dropped: 0
Dropped: 0
Logs are bit messy.
The same source works for lesser image size. so how do i debug further ?
Any help would be greatly appreciable.
