I finaly got the mqtt demo running and now i am able to send JSON messages from the esp32 to a lambda function. In the future the code will be running on many devices. So to be able to differentiate the devices, i’ll need an unique id (For DB related stuff). I know looking through the cloudwatch logs in AWSIotLogsV2 that there is a lot more information that i simply not able to recieve in my lamda function (through the sql Rule). In theory i only the ‘clientId’ or the ‘Thing_name’
One way i found is to make the sql rule like this:
$aws/things/+/topic/subtopic
I’ve tried, didn’t get it work but i also find a bit inapporiate.
An other way i can think of, is just to make sure that the mqtt message has an unique id inside.
If anyone has an idea what i can try or share how you done it, please do.
Thank you, That link guided me to a good source of information.
In the end i found i can add the following to the rule. clientId() as clientId which gives you the thing name.
Now you can use the thing name to differentiate the devices.
@GoldDiggerTh, just want to make it clear that client Id is not necessarily equivalent to the thing name and client Id is not necessarily a unique Id. The broker requires all connected devices to have a unique client Id, but a device can change its client Id and essentially spoof another device if the other device is disconnected. Fortunately, a device cannot connect to the broker using a thing name that is different from the one it’s registered as and has an accompanying certificate to securely connect. To ensure that a device uses the same client Id as it’s registered thing name, you need to enforce it with your device policy. This will ensure that the client Id is unique.
