system
(system)
September 11, 2013, 1:35am
1
greentea514 wrote on Wednesday, September 11, 2013 :
This should be an easy one. I just bought a Atmel SAM4S-EK2 demo board and I wanted to test out FreeRTOS demo
http://www.freertos.org/Atmel_SAM4_SAM4S-EK_RTOS_Demo.html
I get an error I do not recognize. I’d appreciate some help.
---- Build started: Project: RTOSDemo, Configuration: Debug ARM ----
Build started.
Project “RTOSDemo.cproj” (default targets):
Target “PreBuildEvent” skipped, due to false condition; (’$(PreBuildEvent)’!=’’) was evaluated as (’’!=’’).
Target “CoreBuild” in file “C:\Program Files (x86)\Atmel\Atmel Studio 6.1\Vs\Compiler.targets” from project “C:\Users\Yvan\Downloads\FreeRTOSV7.5.2\FreeRTOS\Demo\CORTEX_M4_ATSAM4S_Atmel_Studio\RTOSDemo.cproj” (target “Build” depends on it):
Task “RunCompilerTask”
C:\Program Files (x86)\Atmel\Atmel Studio 6.1\shellUtils\make.exe all
Building file: …/src/asf/sam/drivers/usart/usart.c
Invoking: ARM/GNU C Compiler : 4.7.3
“C:\Program Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4SD32C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\Program Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\Program Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\Program Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/drivers/usart/usart.d” -MT"src/asf/sam/drivers/usart/usart.d" -MT"src/asf/sam/drivers/usart/usart.o" -o “src/asf/sam/drivers/usart/usart.o” “…/src/asf/sam/drivers/usart/usart.c”
Finished building: …/src/asf/sam/drivers/usart/usart.c
make: *** No rule to make target `src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.o’, needed by `RTOSDemo.elf’. Stop.
Done executing task “RunCompilerTask” - FAILED.
Done building target “CoreBuild” in project “RTOSDemo.cproj” - FAILED.
Done building project “RTOSDemo.cproj” - FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
Thanks,
system
(system)
September 11, 2013, 6:01am
2
edwards3 wrote on Wednesday, September 11, 2013 :
It looks like it can’t find the file. Did you run the createprojectdirectorystructure.bat batch file? That copies the files needed by the demo into the folders local to the project file.
system
(system)
September 11, 2013, 10:15pm
3
Yes I did, and I thought it did what it should have done.
I will triple check.
rtel
(Richard Barry)
September 12, 2013, 7:48am
4
rtel wrote on Thursday, September 12, 2013 :
I just tried to compile from a clean install of V7.5.2 and didn’t have an issue. My output is below:
Build started.
Target “CoreBuild” in file “C:\Devtools\Atmel\Atmel Studio 6.1\Vs\Compiler.targets” from project “C:\temp\752\FreeRTOSV7.5.2\FreeRTOS\Demo\CORTEX_M4_ATSAM4S_Atmel_Studio\RTOSDemo.cproj” (target “Build” depends on it):
C:\Devtools\Atmel\Atmel Studio 6.1\shellUtils\make.exe all
Building file: …/src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.d” -MT"src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.d" -MT"src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.o" -o “src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.o” “…/src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.c
Building file: …/src/Common-Demo-Source/QueueSet.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/QueueSet.d” -MT"src/Common-Demo-Source/QueueSet.d" -MT"src/Common-Demo-Source/QueueSet.o" -o “src/Common-Demo-Source/QueueSet.o” “…/src/Common-Demo-Source/QueueSet.c”
Finished building: …/src/Common-Demo-Source/QueueSet.c
Building file: …/src/serial.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/serial.d” -MT"src/serial.d" -MT"src/serial.o" -o “src/serial.o” “…/src/serial.c”
Finished building: …/src/serial.c
Building file: …/src/asf/common/services/clock/sam4s/sysclk.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/common/services/clock/sam4s/sysclk.d” -MT"src/asf/common/services/clock/sam4s/sysclk.d" -MT"src/asf/common/services/clock/sam4s/sysclk.o" -o “src/asf/common/services/clock/sam4s/sysclk.o” “…/src/asf/common/services/clock/sam4s/sysclk.c”
Finished building: …/src/asf/common/services/clock/sam4s/sysclk.c
Building file: …/src/asf/common/utils/interrupt/interrupt_sam_nvic.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/common/utils/interrupt/interrupt_sam_nvic.d” -MT"src/asf/common/utils/interrupt/interrupt_sam_nvic.d" -MT"src/asf/common/utils/interrupt/interrupt_sam_nvic.o" -o “src/asf/common/utils/interrupt/interrupt_sam_nvic.o” “…/src/asf/common/utils/interrupt/interrupt_sam_nvic.c”
Finished building: …/src/asf/common/utils/interrupt/interrupt_sam_nvic.c
Building file: …/src/asf/sam/boards/sam4s_ek/init.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/boards/sam4s_ek/init.d” -MT"src/asf/sam/boards/sam4s_ek/init.d" -MT"src/asf/sam/boards/sam4s_ek/init.o" -o “src/asf/sam/boards/sam4s_ek/init.o” “…/src/asf/sam/boards/sam4s_ek/init.c”
Finished building: …/src/asf/sam/boards/sam4s_ek/init.c
Building file: …/src/asf/sam/drivers/pio/pio.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/drivers/pio/pio.d” -MT"src/asf/sam/drivers/pio/pio.d" -MT"src/asf/sam/drivers/pio/pio.o" -o “src/asf/sam/drivers/pio/pio.o” “…/src/asf/sam/drivers/pio/pio.c”
Finished building: …/src/asf/sam/drivers/pio/pio.c
Building file: …/src/asf/sam/drivers/pio/pio_handler.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/drivers/pio/pio_handler.d” -MT"src/asf/sam/drivers/pio/pio_handler.d" -MT"src/asf/sam/drivers/pio/pio_handler.o" -o “src/asf/sam/drivers/pio/pio_handler.o” “…/src/asf/sam/drivers/pio/pio_handler.c”
Finished building: …/src/asf/sam/drivers/pio/pio_handler.c
Building file: …/src/asf/sam/drivers/pmc/pmc.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/drivers/pmc/pmc.d” -MT"src/asf/sam/drivers/pmc/pmc.d" -MT"src/asf/sam/drivers/pmc/pmc.o" -o “src/asf/sam/drivers/pmc/pmc.o” “…/src/asf/sam/drivers/pmc/pmc.c”
Finished building: …/src/asf/sam/drivers/pmc/pmc.c
Building file: …/src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.d” -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.d" -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.o" -o “src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.o” “…/src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.c”
Finished building: …/src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.c
Building file: …/src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.d” -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.d" -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.o" -o “src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.o” “…/src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.c”
Finished building: …/src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.c
Building file: …/src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.d” -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.d" -MT"src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.o" -o “src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.o” “…/src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.c”
Finished building: …/src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.c
Building file: …/src/asf/thirdparty/FreeRTOS/list.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/list.d” -MT"src/asf/thirdparty/FreeRTOS/list.d" -MT"src/asf/thirdparty/FreeRTOS/list.o" -o “src/asf/thirdparty/FreeRTOS/list.o” “…/src/asf/thirdparty/FreeRTOS/list.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/list.c
Building file: …/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.d” -MT"src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.d" -MT"src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.o" -o “src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.o” “…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.c
Building file: …/src/asf/thirdparty/FreeRTOS/queue.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/queue.d” -MT"src/asf/thirdparty/FreeRTOS/queue.d" -MT"src/asf/thirdparty/FreeRTOS/queue.o" -o “src/asf/thirdparty/FreeRTOS/queue.o” “…/src/asf/thirdparty/FreeRTOS/queue.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/queue.c
Building file: …/src/asf/thirdparty/FreeRTOS/tasks.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/tasks.d” -MT"src/asf/thirdparty/FreeRTOS/tasks.d" -MT"src/asf/thirdparty/FreeRTOS/tasks.o" -o “src/asf/thirdparty/FreeRTOS/tasks.o” “…/src/asf/thirdparty/FreeRTOS/tasks.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/tasks.c
Building file: …/src/asf/thirdparty/FreeRTOS/timers.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/asf/thirdparty/FreeRTOS/timers.d” -MT"src/asf/thirdparty/FreeRTOS/timers.d" -MT"src/asf/thirdparty/FreeRTOS/timers.o" -o “src/asf/thirdparty/FreeRTOS/timers.o” “…/src/asf/thirdparty/FreeRTOS/timers.c”
Finished building: …/src/asf/thirdparty/FreeRTOS/timers.c
Building file: …/src/Common-Demo-Source/BlockQ.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/BlockQ.d” -MT"src/Common-Demo-Source/BlockQ.d" -MT"src/Common-Demo-Source/BlockQ.o" -o “src/Common-Demo-Source/BlockQ.o” “…/src/Common-Demo-Source/BlockQ.c”
Finished building: …/src/Common-Demo-Source/BlockQ.c
Building file: …/src/Common-Demo-Source/blocktim.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/blocktim.d” -MT"src/Common-Demo-Source/blocktim.d" -MT"src/Common-Demo-Source/blocktim.o" -o “src/Common-Demo-Source/blocktim.o” “…/src/Common-Demo-Source/blocktim.c”
Finished building: …/src/Common-Demo-Source/blocktim.c
Building file: …/src/Common-Demo-Source/comtest.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/comtest.d” -MT"src/Common-Demo-Source/comtest.d" -MT"src/Common-Demo-Source/comtest.o" -o “src/Common-Demo-Source/comtest.o” “…/src/Common-Demo-Source/comtest.c”
Finished building: …/src/Common-Demo-Source/comtest.c
Building file: …/src/Common-Demo-Source/countsem.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/countsem.d” -MT"src/Common-Demo-Source/countsem.d" -MT"src/Common-Demo-Source/countsem.o" -o “src/Common-Demo-Source/countsem.o” “…/src/Common-Demo-Source/countsem.c”
Finished building: …/src/Common-Demo-Source/countsem.c
Building file: …/src/Common-Demo-Source/death.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/death.d” -MT"src/Common-Demo-Source/death.d" -MT"src/Common-Demo-Source/death.o" -o “src/Common-Demo-Source/death.o” “…/src/Common-Demo-Source/death.c”
Finished building: …/src/Common-Demo-Source/death.c
Building file: …/src/Common-Demo-Source/dynamic.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/dynamic.d” -MT"src/Common-Demo-Source/dynamic.d" -MT"src/Common-Demo-Source/dynamic.o" -o “src/Common-Demo-Source/dynamic.o” “…/src/Common-Demo-Source/dynamic.c”
Finished building: …/src/Common-Demo-Source/dynamic.c
Building file: …/src/Common-Demo-Source/flash_timer.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/flash_timer.d” -MT"src/Common-Demo-Source/flash_timer.d" -MT"src/Common-Demo-Source/flash_timer.o" -o “src/Common-Demo-Source/flash_timer.o” “…/src/Common-Demo-Source/flash_timer.c”
Finished building: …/src/Common-Demo-Source/flash_timer.c
Building file: …/src/Common-Demo-Source/GenQTest.c
Invoking: ARM/GNU C Compiler : 4.7.3
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/GenQTest.d” -MT"src/Common-Demo-Source/GenQTest.d" -MT"src/Common-Demo-Source/GenQTest.o" -o “src/Common-Demo-Source/GenQTest.o” “…/src/Common-Demo-Source/GenQTest.c”
Finished building: …/src/Common-Demo-Source/GenQTest.c
Building file: …/src/Common-Demo-Source/integer.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/integer.d” -MT"src/Common-Demo-Source/integer.d" -MT"src/Common-Demo-Source/integer.o" -o “src/Common-Demo-Source/integer.o” “…/src/Common-Demo-Source/integer.c”
Finished building: …/src/Common-Demo-Source/integer.c
Building file: …/src/Common-Demo-Source/PollQ.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/PollQ.d” -MT"src/Common-Demo-Source/PollQ.d" -MT"src/Common-Demo-Source/PollQ.o" -o “src/Common-Demo-Source/PollQ.o” “…/src/Common-Demo-Source/PollQ.c”
Finished building: …/src/Common-Demo-Source/PollQ.c
Building file: …/src/Common-Demo-Source/recmutex.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/recmutex.d” -MT"src/Common-Demo-Source/recmutex.d" -MT"src/Common-Demo-Source/recmutex.o" -o “src/Common-Demo-Source/recmutex.o” “…/src/Common-Demo-Source/recmutex.c”
Finished building: …/src/Common-Demo-Source/recmutex.c
Building file: …/src/Common-Demo-Source/semtest.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/Common-Demo-Source/semtest.d” -MT"src/Common-Demo-Source/semtest.d" -MT"src/Common-Demo-Source/semtest.o" -o “src/Common-Demo-Source/semtest.o” “…/src/Common-Demo-Source/semtest.c”
Finished building: …/src/Common-Demo-Source/semtest.c
Building file: …/src/main.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/main.d” -MT"src/main.d" -MT"src/main.o" -o “src/main.o” “…/src/main.c”
Finished building: …/src/main.c
Building file: …/src/main_blinky.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/main_blinky.d” -MT"src/main_blinky.d" -MT"src/main_blinky.o" -o “src/main_blinky.o” “…/src/main_blinky.c”
Finished building: …/src/main_blinky.c
Building file: …/src/main_full.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/main_full.d” -MT"src/main_full.d" -MT"src/main_full.o" -o “src/main_full.o” “…/src/main_full.c”
Finished building: …/src/main_full.c
Building file: …/src/ParTest.c
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -mthumb -D__SAM4S16C__ -DARM_MATH_CM4=true -DBOARD=SAM4S_EK -D__SAM4S16C__ -DXMEGA=0 -DMEGA=0 -DUC3=0 -I"…/src" -I"…/src/asf/common/applications/user_application/sam4s16c_sam4s_ek" -I"…/src/asf/common/boards" -I"…/src/asf/common/services/gpio" -I"…/src/asf/common/utils" -I"…/src/asf/sam/boards" -I"…/src/asf/sam/boards/sam4s_ek" -I"…/src/asf/sam/drivers/pio" -I"…/src/asf/sam/utils" -I"…/src/asf/sam/utils/cmsis/sam4s/include" -I"…/src/asf/sam/utils/cmsis/sam4s/source/templates" -I"…/src/asf/sam/utils/header_files" -I"…/src/asf/sam/utils/preprocessor" -I"…/src/asf/thirdparty/CMSIS/Include" -I"…/src/asf/thirdparty/CMSIS/Lib/GCC" -I"…/src/config" -I"…/src/asf/thirdparty/FreeRTOS/include" -I"…/src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3" -I"…/src/Common-Demo-Source/include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC\3.3.1.83\ARMSupportFiles\Device\ATMEL\sam4s\include" -I"…/src/asf/sam/drivers/pmc" -I"…/src/asf/common/services/clock" -I"…/src/asf/sam/drivers/usart" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\CMSIS\Include" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL" -I"C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\…\…\CMSIS_Atmel\Device\ATMEL\sam4s\include" -O0 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m4 -c -pipe -Wall -Wextra -std=gnu99 -ffunction-sections -fdata-sections -param max-inline-insns-single=500 -Dprintf=iprintf -MD -MP -MF “src/ParTest.d” -MT"src/ParTest.d" -MT"src/ParTest.o" -o “src/ParTest.o” “…/src/ParTest.c”
Finished building: …/src/ParTest.c
Building target: RTOSDemo.elf
Invoking: ARM/GNU Linker : 4.7.3
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe” -o RTOSDemo.elf src/asf/sam/drivers/usart/usart.o src/asf/thirdparty/FreeRTOS/portable/MemMang/heap_4.o src/Common-Demo-Source/QueueSet.o src/serial.o src/asf/common/services/clock/sam4s/sysclk.o src/asf/common/utils/interrupt/interrupt_sam_nvic.o src/asf/sam/boards/sam4s_ek/init.o src/asf/sam/drivers/pio/pio.o src/asf/sam/drivers/pio/pio_handler.o src/asf/sam/drivers/pmc/pmc.o src/asf/sam/utils/cmsis/sam4s/source/templates/exceptions.o src/asf/sam/utils/cmsis/sam4s/source/templates/gcc/startup_sam4s.o src/asf/sam/utils/cmsis/sam4s/source/templates/system_sam4s.o src/asf/thirdparty/FreeRTOS/list.o src/asf/thirdparty/FreeRTOS/portable/GCC/ARM_CM3/port.o src/asf/thirdparty/FreeRTOS/queue.o src/asf/thirdparty/FreeRTOS/tasks.o src/asf/thirdparty/FreeRTOS/timers.o src/Common-Demo-Source/BlockQ.o src/Common-Demo-Source/blocktim.o src/Common-Demo-Source/comtest.o src/Common-Demo-Source/countsem.o src/Common-Demo-Source/death.o src/Common-Demo-Source/dynamic.o src/Common-Demo-Source/flash_timer.o src/Common-Demo-Source/GenQTest.o src/Common-Demo-Source/integer.o src/Common-Demo-Source/PollQ.o src/Common-Demo-Source/recmutex.o src/Common-Demo-Source/semtest.o src/main.o src/main_blinky.o src/main_full.o src/ParTest.o -mthumb -Wl,-Map=“RTOSDemo.map” -Wl,-start-group -Wl,-end-group -L"…/src/asf/thirdparty/CMSIS/Lib/GCC" -Wl,-gc-sections -mcpu=cortex-m4 -T…/src/asf/sam/utils/linker_scripts/sam4s/sam4s16/gcc/flash.ld -Wl,-cref -Wl,-entry=Reset_Handler -mthumb
Finished building target: RTOSDemo.elf
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe” -O binary “RTOSDemo.elf” “RTOSDemo.bin”
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe” -O ihex -R .eeprom -R .fuse -R .lock -R .signature “RTOSDemo.elf” “RTOSDemo.hex”
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe” -j .eeprom -set-section-flags=.eeprom=alloc,load -change-section-lma .eeprom=0 -no-change-warnings -O binary “RTOSDemo.elf” “RTOSDemo.eep” || exit 0
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-objdump.exe” -h -S “RTOSDemo.elf” > “RTOSDemo.lss”
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe” -O srec -R .eeprom -R .fuse -R .lock -R .signature “RTOSDemo.elf” “RTOSDemo.srec”
“C:\devtools\Atmel\Atmel Toolchain\ARM GCC\Native\4.7.3.1029\arm-gnu-toolchain\bin\arm-none-eabi-size.exe” “RTOSDemo.elf”
text data bss dec hex filename
38516 1104 54088 93708 16e0c RTOSDemo.elf
Done executing task “RunCompilerTask”.
Using “RunOutputFileVerifyTask” task from assembly “C:\Devtools\Atmel\Atmel Studio 6.1\Extensions\Application\AvrGCC.dll”.
Task “RunOutputFileVerifyTask”
Program Memory Usage : 39620 bytes 3.8 % Full
Data Memory Usage : 55192 bytes 42.1 % Full
Done executing task “RunOutputFileVerifyTask”.
Done building target “CoreBuild” in project “RTOSDemo.cproj”.
Target “PostBuildEvent” skipped, due to false condition; (’$(PostBuildEvent)’ != ‘’) was evaluated as (’’ != ‘’).
Target “Build” in file “C:\Devtools\Atmel\Atmel Studio 6.1\Vs\Avr.common.targets” from project “C:\temp\752\FreeRTOSV7.5.2\FreeRTOS\Demo\CORTEX_M4_ATSAM4S_Atmel_Studio\RTOSDemo.cproj” (entry point):
Done building target “Build” in project “RTOSDemo.cproj”.
Done building project “RTOSDemo.cproj”.
Build succeeded.
========== Build: 1 succeeded or up-to-date, 0 failed, 0 skipped ==========
