system
(system)
March 16, 2007, 9:19am
1
nobody wrote on Friday, March 16, 2007 :
I’m using the AT91SAM7x evaluation board from Atmel with the AT91SAM7x256
microcontroller. I’m using eclipse and I like to run FreeRTOS.
I have downloaded; FreeRTOS.org/lwIP/USB WEB server Demo for GCC
My question is, how to compile this?
If I like to make it, I will get the following:
make: *** No rule to make target `all’.
Do I have to change something in the makefile? Or what commands do I have to
use in my commandline??
rtel
(Richard Barry)
March 16, 2007, 9:26am
2
rtel wrote on Friday, March 16, 2007 :
I…
1) Create a new FreeRTOS.org installation.
2) Setup the correct paths to my GCC compiler.
3) Go into the FreeRTOS/Demo/lwIP_Demo_Rowley_ARM7 directory and type "make" [**note, not "make all"**], and get the following output, with apparently no problem:
C:\Temp\FreeRTOS\Demo\lwIP_Demo_Rowley_ARM7>make
arm-elf-gcc -c -I. -I./EMAC -I…/Common/include -I./USB -I./lwip-1.1.0/src/include -I./lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X -I…/…/So
urce/include -I…/…/Source/portable/GCC/ARM7_AT91SAM7S -I./lwip-1.1.0/src/include/ipv4 -Wall -Wextra -Wstrict-prototypes -Wmissing-prototyp
es -Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0 …/…/S
ource/portable/GCC/ARM7_AT91SAM7S/portISR.c -o …/…/Source/portable/GCC/ARM7_AT91SAM7S/portISR.o
es -Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0 EMAC/SA
M7_EMAC_ISR.c -o EMAC/SAM7_EMAC_ISR.o
es -Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0 USB/USB
Isr.c -o USB/USBIsr.o
es -Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0 Cstartu
p_SAM7.c -o Cstartup_SAM7.o
arm-elf-gcc -c -mthumb -I. -I./EMAC -I…/Common/include -I./USB -I./lwip-1.1.0/src/include -I./lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X -I
…/…/Source/include -I…/…/Source/portable/GCC/ARM7_AT91SAM7S -I./lwip-1.1.0/src/include/ipv4 -Wall -Wextra -Wstrict-prototypes -Wmissing-
prototypes -Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0
…/…/Source/portable/MemMang/heap_2.c -o …/…/Source/portable/MemMang/heap_2.o
ParTest/ParTest.c -o ParTest/ParTest.o
main.c -o main.o
…/Common/Minimal/flash.c -o …/Common/Minimal/flash.o
…/Common/Minimal/BlockQ.c -o …/Common/Minimal/BlockQ.o
…/Common/Minimal/integer.c -o …/Common/Minimal/integer.o
…/Common/Minimal/PollQ.c -o …/Common/Minimal/PollQ.o
…/Common/Minimal/semtest.c -o …/Common/Minimal/semtest.o
BasicWEB.c -o BasicWEB.o
USB/USB-CDC.c -o USB/USB-CDC.o
lwip-1.1.0/src/core/tcp_out.c -o lwip-1.1.0/src/core/tcp_out.o
lwip-1.1.0/src/core/inet.c -o lwip-1.1.0/src/core/inet.o
lwip-1.1.0/src/core/mem.c -o lwip-1.1.0/src/core/mem.o
lwip-1.1.0/src/core/memp.c -o lwip-1.1.0/src/core/memp.o
lwip-1.1.0/src/core/netif.c -o lwip-1.1.0/src/core/netif.o
lwip-1.1.0/src/core/pbuf.c -o lwip-1.1.0/src/core/pbuf.o
lwip-1.1.0/src/core/raw.c -o lwip-1.1.0/src/core/raw.o
lwip-1.1.0/src/core/stats.c -o lwip-1.1.0/src/core/stats.o
lwip-1.1.0/src/core/sys.c -o lwip-1.1.0/src/core/sys.o
lwip-1.1.0/src/core/tcp.c -o lwip-1.1.0/src/core/tcp.o
lwip-1.1.0/src/core/tcp_in.c -o lwip-1.1.0/src/core/tcp_in.o
lwip-1.1.0/src/core/ipv4/ip.c -o lwip-1.1.0/src/core/ipv4/ip.o
lwip-1.1.0/src/core/ipv4/ip_addr.c -o lwip-1.1.0/src/core/ipv4/ip_addr.o
lwip-1.1.0/src/core/ipv4/icmp.c -o lwip-1.1.0/src/core/ipv4/icmp.o
lwip-1.1.0/src/api/tcpip.c -o lwip-1.1.0/src/api/tcpip.o
lwip-1.1.0/src/api/api_msg.c -o lwip-1.1.0/src/api/api_msg.o
lwip-1.1.0/src/api/err.c -o lwip-1.1.0/src/api/err.o
lwip-1.1.0/src/api/api_lib.c -o lwip-1.1.0/src/api/api_lib.o
lwip-1.1.0/src/netif/etharp.c -o lwip-1.1.0/src/netif/etharp.o
lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X/sys_arch.c -o lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X/sys_arch.o
lwip-1.1.0/src/netif/ethernetif.c -o lwip-1.1.0/src/netif/ethernetif.o
EMAC/SAM7_EMAC.c -o EMAC/SAM7_EMAC.o
lwip-1.1.0/src/core/udp.c -o lwip-1.1.0/src/core/udp.o
lwip-1.1.0/src/core/ipv4/ip_frag.c -o lwip-1.1.0/src/core/ipv4/ip_frag.o
…/…/Source/tasks.c -o …/…/Source/tasks.o
…/…/Source/queue.c -o …/…/Source/queue.o
…/…/Source/list.c -o …/…/Source/list.o
…/…/Source/portable/GCC/ARM7_AT91SAM7S/port.c -o …/…/Source/portable/GCC/ARM7_AT91SAM7S/port.o
arm-elf-gcc -I. -I./EMAC -I…/Common/include -I./USB -I./lwip-1.1.0/src/include -I./lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X -I…/…/Sourc
e/include -I…/…/Source/portable/GCC/ARM7_AT91SAM7S -I./lwip-1.1.0/src/include/ipv4 -Wall -Wextra -Wstrict-prototypes -Wmissing-prototypes
-Wmissing-declarations -Wno-strict-aliasing -D SAM7_GCC -D THUMB_INTERWORK -mthumb-interwork -mcpu=arm7tdmi -Tatmel-rom.ld -g -O0 …/…/Sour
ce/portable/GCC/ARM7_AT91SAM7S/portISR.o EMAC/SAM7_EMAC_ISR.o USB/USBIsr.o Cstartup_SAM7.o …/…/Source/portable/MemMang/heap_2.o ParTest/
ParTest.o main.o …/Common/Minimal/flash.o …/Common/Minimal/BlockQ.o …/Common/Minimal/integer.o …/Common/Minimal/PollQ.o …/Common/Minima
l/semtest.o BasicWEB.o USB/USB-CDC.o lwip-1.1.0/src/core/tcp_out.o lwip-1.1.0/src/core/inet.o lwip-1.1.0/src/core/mem.o lwip-1.1.0/src/core
/memp.o lwip-1.1.0/src/core/netif.o lwip-1.1.0/src/core/pbuf.o lwip-1.1.0/src/core/raw.o lwip-1.1.0/src/core/stats.o lwip-1.1.0/src/core/sys
.o lwip-1.1.0/src/core/tcp.o lwip-1.1.0/src/core/tcp_in.o lwip-1.1.0/src/core/ipv4/ip.o lwip-1.1.0/src/core/ipv4/ip_addr.o lwip-1.1.0/src/co
re/ipv4/icmp.o lwip-1.1.0/src/api/tcpip.o lwip-1.1.0/src/api/api_msg.o lwip-1.1.0/src/api/err.o lwip-1.1.0/src/api/api_lib.o lwip-1.1.0/src/
netif/etharp.o lwip-1.1.0/contrib/port/FreeRTOS/AT91SAM7X/sys_arch.o lwip-1.1.0/src/netif/ethernetif.o EMAC/SAM7_EMAC.o lwip-1.1.0/src/core/
udp.o lwip-1.1.0/src/core/ipv4/ip_frag.o …/…/Source/tasks.o …/…/Source/queue.o …/…/Source/list.o …/…/Source/portable/GCC/ARM7_AT91SA
M7S/port.o -nostartfiles boot.s -Xlinker -ortosdemo.elf -Xlinker -M -Xlinker -Map=rtosdemo.map
arm-elf-objcopy rtosdemo.elf -O binary rtosdemo.bin
system
(system)
March 16, 2007, 11:46am
3
Thank you!
Can I compile this in eclipse?
Now I have compiled it with the command line.
If it is possible in eclipse, which settings have to be made?
Regards
chaalar
(chaalar)
March 16, 2007, 1:18pm
4
chaalar wrote on Friday, March 16, 2007 :
I guess you are creating your build target in the wrong directory under Eclipse. Please create it in the directory where your Makefile resides.
system
(system)
March 16, 2007, 1:47pm
5
Hi!
There is good tutorial about using eclipse/openocd etc. on http://www.yagarto.de (or link to that tutorial would be more correct…)
Madis
