jmr1972 wrote on Monday, January 10, 2011:
I did have a working port to the Xmega644 but haven’t touched it in 2 years+ so won’t be able to help with getting the port into the latest FreeRTOS version.
I seem to remember having to modify the portSAVE_CONTEXT() and portRESTORE_CONTEXT() macros to get it to work as well as the tick interrupt part of the port.c file.
here’s the contents of port.c:
FreeRTOS.org V4.6.1 - Copyright (C) 2003-2007 Richard Barry.
This file is part of the FreeRTOS.org distribution.
FreeRTOS.org is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
FreeRTOS.org is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with FreeRTOS.org; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
A special exception to the GPL can be applied should you wish to distribute
a combined work that includes FreeRTOS.org, without being obliged to provide
the source code for any proprietary components. See the licensing section
of http://www.FreeRTOS.org for full details of how and when the exception
can be applied.
See http://www.FreeRTOS.org for documentation, latest information, license
and contact details. Please ensure to read the configuration and relevant
port sections of the online documentation.
Also see http://www.SafeRTOS.com a version that has been certified for use
in safety critical systems, plus commercial licensing, development and
support options.
Changes from V2.6.0
+ AVR port - Replaced the inb() and outb() functions with direct memory
access. This allows the port to be built with the 20050414 build of
WinAVR.
#include <stdlib.h>
#include <avr/interrupt.h>
#include "FreeRTOS.h"
#include "task.h"
* Implementation of functions defined in portable.h for the AVR port.
/* Start tasks with interrupts enables. */
#define portFLAGS_INT_ENABLED ( ( portSTACK_TYPE ) 0x80 )
/* Hardware constants for timer 1. */
#define portCLEAR_COUNTER_ON_MATCH ( ( unsigned portCHAR ) 0x08 )
#define portPRESCALE_64 ( ( unsigned portCHAR ) 0x03 )
#define portCLOCK_PRESCALER ( ( unsigned portLONG ) 64 )
#define portCOMPARE_MATCH_A_INTERRUPT_ENABLE ( ( unsigned portCHAR ) 0x02 )
/* We require the address of the pxCurrentTCB variable, but don't want to know
any details of its type. */
typedef void tskTCB;
extern volatile tskTCB * volatile pxCurrentTCB;
* Macro to save all the general purpose registers, the save the stack pointer
* into the TCB.
* The first thing we do is save the flags then disable interrupts. This is to
* guard our stack against having a context switch interrupt after we have already
* pushed the registers onto the stack - causing the 32 registers to be on the
* stack twice.
* r1 is set to zero as the compiler expects it to be thus, however some
* of the math routines make use of R1.
* The interrupts will have been disabled during the call to portSAVE_CONTEXT()
* so we need not worry about reading/writing to the stack pointer.
#define portSAVE_CONTEXT() \
asm volatile ( "push r0 \n\t" \
"in r0, __SREG__ \n\t" \
"cli \n\t" \
"push r0 \n\t" \
"push r1 \n\t" \
"clr r1 \n\t" \
"push r2 \n\t" \
"push r3 \n\t" \
"push r4 \n\t" \
"push r5 \n\t" \
"push r6 \n\t" \
"push r7 \n\t" \
"push r8 \n\t" \
"push r9 \n\t" \
"push r10 \n\t" \
"push r11 \n\t" \
"push r12 \n\t" \
"push r13 \n\t" \
"push r14 \n\t" \
"push r15 \n\t" \
"push r16 \n\t" \
"push r17 \n\t" \
"push r18 \n\t" \
"push r19 \n\t" \
"push r20 \n\t" \
"push r21 \n\t" \
"push r22 \n\t" \
"push r23 \n\t" \
"push r24 \n\t" \
"push r25 \n\t" \
"push r26 \n\t" \
"push r27 \n\t" \
"push r28 \n\t" \
"push r29 \n\t" \
"push r30 \n\t" \
"push r31 \n\t" \
"lds r26, pxCurrentTCB \n\t" \
"lds r27, pxCurrentTCB + 1 \n\t" \
"in r0, 0x3d \n\t" \
"st x+, r0 \n\t" \
"in r0, 0x3e \n\t" \
"st x+, r0 \n\t" \
* Opposite to portSAVE_CONTEXT(). Interrupts will have been disabled during
* the context save so we can write to the stack pointer.
#define portRESTORE_CONTEXT() \
asm volatile ( "lds r26, pxCurrentTCB \n\t" \
"ld r28, x+ \n\t" \
"out __SP_L__, r28 \n\t" \
"ld r29, x+ \n\t" \
"out __SP_H__, r29 \n\t" \
"pop r31 \n\t" \
"pop r30 \n\t" \
"pop r29 \n\t" \
"pop r28 \n\t" \
"pop r27 \n\t" \
"pop r26 \n\t" \
"pop r25 \n\t" \
"pop r24 \n\t" \
"pop r23 \n\t" \
"pop r22 \n\t" \
"pop r21 \n\t" \
"pop r20 \n\t" \
"pop r19 \n\t" \
"pop r18 \n\t" \
"pop r17 \n\t" \
"pop r16 \n\t" \
"pop r15 \n\t" \
"pop r14 \n\t" \
"pop r13 \n\t" \
"pop r12 \n\t" \
"pop r11 \n\t" \
"pop r10 \n\t" \
"pop r9 \n\t" \
"pop r8 \n\t" \
"pop r7 \n\t" \
"pop r6 \n\t" \
"pop r5 \n\t" \
"pop r4 \n\t" \
"pop r3 \n\t" \
"pop r2 \n\t" \
"pop r1 \n\t" \
"pop r0 \n\t" \
"out __SREG__, r0 \n\t" \
"pop r0 \n\t" \
* Perform hardware setup to enable ticks from timer 1, compare match A.
static void prvSetupTimerInterrupt( void );
* See header file for description.
portSTACK_TYPE *pxPortInitialiseStack( portSTACK_TYPE *pxTopOfStack, pdTASK_CODE pxCode, void *pvParameters )
unsigned portSHORT usAddress;
/* Place a few bytes of known values on the bottom of the stack.
This is just useful for debugging. */
*pxTopOfStack = 0x11;
pxTopOfStack--;
*pxTopOfStack = 0x22;
pxTopOfStack--;
*pxTopOfStack = 0x33;
pxTopOfStack--;
/* Simulate how the stack would look after a call to vPortYield() generated by
the compiler. */
/*lint -e950 -e611 -e923 Lint doesn't like this much - but nothing I can do about it. */
/* The start of the task code will be popped off the stack last, so place
it on first. */
usAddress = ( unsigned portSHORT ) pxCode;
*pxTopOfStack = ( portSTACK_TYPE ) ( usAddress & ( unsigned portSHORT ) 0x00ff );
pxTopOfStack--;
usAddress >>= 8;
pxTopOfStack--;
/* Next simulate the stack as if after a call to portSAVE_CONTEXT().
portSAVE_CONTEXT places the flags on the stack immediately after r0
to ensure the interrupts get disabled as soon as possible, and so ensuring
the stack use is minimal should a context switch interrupt occur. */
*pxTopOfStack = ( portSTACK_TYPE ) 0x00; /* R0 */
pxTopOfStack--;
*pxTopOfStack = portFLAGS_INT_ENABLED;
pxTopOfStack--;
/* Now the remaining registers. The compiler expects R1 to be 0. */
*pxTopOfStack = ( portSTACK_TYPE ) 0x00; /* R1 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x02; /* R2 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x03; /* R3 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x04; /* R4 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x05; /* R5 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x06; /* R6 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x07; /* R7 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x08; /* R8 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x09; /* R9 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x10; /* R10 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x11; /* R11 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x12; /* R12 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x13; /* R13 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x14; /* R14 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x15; /* R15 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x16; /* R16 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x17; /* R17 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x18; /* R18 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x19; /* R19 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x20; /* R20 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x21; /* R21 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x22; /* R22 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x23; /* R23 */
pxTopOfStack--;
/* Place the parameter on the stack in the expected location. */
usAddress = ( unsigned portSHORT ) pvParameters;
pxTopOfStack--;
usAddress >>= 8;
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x26; /* R26 X */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x27; /* R27 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x28; /* R28 Y */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x29; /* R29 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x30; /* R30 Z */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x031; /* R31 */
pxTopOfStack--;
/*lint +e950 +e611 +e923 */
return pxTopOfStack;
portBASE_TYPE xPortStartScheduler( void )
/* In this port we ignore the parameter and use the configUSE_PREEMPTION
definition instead. */
/* Setup the hardware to generate the tick. */
prvSetupTimerInterrupt();
/* Restore the context of the first task that is going to run. */
portRESTORE_CONTEXT();
/* Simulate a function call end as generated by the compiler. We will now
jump to the start of the task the context of which we have just restored. */
asm volatile ( "ret" );
/* Should not get here. */
return pdTRUE;
void vPortEndScheduler( void )
/* It is unlikely that the AVR port will get stopped. If required simply
disable the tick interrupt here. */
* Manual context switch. The first thing we do is save the registers so we
* can use a naked attribute.
void vPortYield( void ) __attribute__ ( ( naked ) );
portSAVE_CONTEXT();
vTaskSwitchContext();
* Context switch function used by the tick. This must be identical to
* vPortYield() from the call to vTaskSwitchContext() onwards. The only
* difference from vPortYield() is the tick count is incremented as the
* call comes from the tick ISR.
void vPortYieldFromTick( void ) __attribute__ ( ( naked ) );
portSAVE_CONTEXT();
vTaskIncrementTick();
* Setup timer 1 compare match A to generate a tick interrupt.
unsigned portLONG ulCompareMatch;
unsigned portCHAR ucHighByte, ucLowByte;
/* Using 16bit timer 1 to generate the tick. Correct fuses must be
selected for the configCPU_CLOCK_HZ clock. */
ulCompareMatch = configCPU_CLOCK_HZ / portCLOCK_PRESCALER;
/* calculates the RTOS tick rate based on the timer's tick rate. */
ulCompareMatch /= configTICK_RATE_HZ;
/* Adjust for correct value. */
ulCompareMatch -= ( unsigned portLONG ) 1;
//ulCompareMatch = (unsigned portLONG) 8639;
/* Setup compare match value for compare match A. Interrupts are disabled
before this is called so we need not worry here. */
ucLowByte = ( unsigned portCHAR ) ( ulCompareMatch & ( unsigned portLONG ) 0xff );
ulCompareMatch >>= 8;
ucHighByte = ( unsigned portCHAR ) ( ulCompareMatch & ( unsigned portLONG ) 0xff );
OCR1AH = ucHighByte;
OCR1AL = ucLowByte;
/* Setup clock source and compare match behaviour. */
ucLowByte = portCLEAR_COUNTER_ON_MATCH | portPRESCALE_64;
TCCR1B = ucLowByte;
/* Enable the interrupt - this is okay as interrupt are currently globally
disabled. */
ucLowByte = TIMSK1;
ucLowByte |= portCOMPARE_MATCH_A_INTERRUPT_ENABLE;
TIMSK1 = ucLowByte;
#if configUSE_PREEMPTION == 1
* Tick ISR for preemptive scheduler. We can use a naked attribute as
* the context is saved at the start of vPortYieldFromTick(). The tick
* count is incremented after the context is saved.
void SIG_OUTPUT_COMPARE1A( void ) __attribute__ ( ( signal, naked ) );
vPortYieldFromTick();
asm volatile ( "reti" );
#else
* Tick ISR for the cooperative scheduler. All this does is increment the
* tick count. We don't need to switch context, this can only be done by
* manual calls to taskYIELD();
void SIG_OUTPUT_COMPARE1A( void ) __attribute__ ( ( signal ) );
and here’s my portmacro.h
FreeRTOS.org V5.0.2 - Copyright (C) 2003-2008 Richard Barry.
can be applied.
* SAVE TIME AND MONEY! We can port FreeRTOS.org to your own hardware, *
* and even write all or part of your application on your behalf. *
* See http://www.OpenRTOS.com for details of the services we provide to *
* expedite your project. *
Please ensure to read the configuration and relevant port sections of the
http://www.FreeRTOS.org - Documentation, latest information, license and
contact details.
http://www.SafeRTOS.com - A version that is certified for use in safety
critical systems.
http://www.OpenRTOS.com - Commercial support, development, porting,
licensing and training services.
Changes from V1.2.3
+ portCPU_CLOSK_HZ definition changed to 8MHz base 10, previously it
base 16.
#ifndef PORTMACRO_H
#define PORTMACRO_H
#ifdef __cplusplus
extern "C" {
* Port specific definitions.
* The settings in this file configure FreeRTOS correctly for the
* given hardware and compiler.
* These settings should not be altered.
/* Type definitions. */
#define portCHAR char
#define portFLOAT float
#define portDOUBLE double
#define portLONG long
#define portSHORT int
#define portSTACK_TYPE unsigned portCHAR
#define portBASE_TYPE char
#if( configUSE_16_BIT_TICKS == 1 )
typedef unsigned portSHORT portTickType;
#define portMAX_DELAY ( portTickType ) 0xffff
#else
typedef unsigned portLONG portTickType;
#define portMAX_DELAY ( portTickType ) 0xffffffff
/* Critical section management. */
#define portENTER_CRITICAL() asm volatile ( "in __tmp_reg__, __SREG__" :: ); \
asm volatile ( "cli" :: ); \
asm volatile ( "push __tmp_reg__" :: )
#define portEXIT_CRITICAL() asm volatile ( "pop __tmp_reg__" :: ); \
asm volatile ( "out __SREG__, __tmp_reg__" :: )
#define portDISABLE_INTERRUPTS() asm volatile ( "cli" :: );
#define portENABLE_INTERRUPTS() asm volatile ( "sei" :: );
/* Architecture specifics. */
#define portSTACK_GROWTH ( -1 )
#define portTICK_RATE_MS ( ( portTickType ) 1000 / configTICK_RATE_HZ )
#define portBYTE_ALIGNMENT 1
#define portNOP() asm volatile ( "nop" );
/* Kernel utilities. */
extern void vPortYield( void ) __attribute__ ( ( naked ) );
#define portYIELD() vPortYield()
/* Task function macros as described on the FreeRTOS.org WEB site. */
#define portTASK_FUNCTION_PROTO( vFunction, pvParameters ) void vFunction( void *pvParameters )
#define portTASK_FUNCTION( vFunction, pvParameters ) void vFunction( void *pvParameters )
#ifdef __cplusplus
#endif /* PORTMACRO_H */
I think that’s all that needs modifying to get things up and running…
