Hello!
I have some problems with configuration of FreeRTOS for ATmega1284P. It was working with my ATmega32A then i habe chnged it to ATmega1284P. I think the problem is in the port.c file. It doesnt generate ticks for programm. I have already tried to configure it myself but wothout success. Could anybody help me please?
Here are the port.c file with ma changes
#include <stdlib.h>
#include <avr/interrupt.h>
#include "FreeRTOS.h"
#include "task.h"
* Implementation of functions defined in portable.h for the AVR port.
/* Start tasks with interrupts enables. */
#define portFLAGS_INT_ENABLED ( ( portSTACK_TYPE ) 0x80 )
/* Hardware constants for timer 1. */
#define portCLEAR_COUNTER_ON_MATCH ( ( unsigned char ) 0x08 )
#define portPRESCALE_64 ( ( unsigned char ) 0x03 )
#define portCLOCK_PRESCALER ( ( unsigned long ) 64 )
#define portCOMPARE_MATCH_A_INTERRUPT_ENABLE ( ( unsigned char ) 0x02 )
/* We require the address of the pxCurrentTCB variable, but don't want to know
any details of its type. */
typedef void tskTCB;
extern volatile tskTCB * volatile pxCurrentTCB;
* Macro to save all the general purpose registers, the save the stack pointer
* into the TCB.
* The first thing we do is save the flags then disable interrupts. This is to
* guard our stack against having a context switch interrupt after we have already
* pushed the registers onto the stack - causing the 32 registers to be on the
* stack twice.
* r1 is set to zero as the compiler expects it to be thus, however some
* of the math routines make use of R1.
* The interrupts will have been disabled during the call to portSAVE_CONTEXT()
* so we need not worry about reading/writing to the stack pointer.
#define portSAVE_CONTEXT() \
asm volatile ( "push r0 \n\t" \
"in r0, __SREG__ \n\t" \
"cli \n\t" \
"push r0 \n\t" \
"push r1 \n\t" \
"clr r1 \n\t" \
"push r2 \n\t" \
"push r3 \n\t" \
"push r4 \n\t" \
"push r5 \n\t" \
"push r6 \n\t" \
"push r7 \n\t" \
"push r8 \n\t" \
"push r9 \n\t" \
"push r10 \n\t" \
"push r11 \n\t" \
"push r12 \n\t" \
"push r13 \n\t" \
"push r14 \n\t" \
"push r15 \n\t" \
"push r16 \n\t" \
"push r17 \n\t" \
"push r18 \n\t" \
"push r19 \n\t" \
"push r20 \n\t" \
"push r21 \n\t" \
"push r22 \n\t" \
"push r23 \n\t" \
"push r24 \n\t" \
"push r25 \n\t" \
"push r26 \n\t" \
"push r27 \n\t" \
"push r28 \n\t" \
"push r29 \n\t" \
"push r30 \n\t" \
"push r31 \n\t" \
"lds r26, pxCurrentTCB \n\t" \
"lds r27, pxCurrentTCB + 1 \n\t" \
"in r0, 0x3d \n\t" \
"st x+, r0 \n\t" \
"in r0, 0x3e \n\t" \
"st x+, r0 \n\t" \
* Opposite to portSAVE_CONTEXT(). Interrupts will have been disabled during
* the context save so we can write to the stack pointer.
#define portRESTORE_CONTEXT() \
asm volatile ( "lds r26, pxCurrentTCB \n\t" \
"ld r28, x+ \n\t" \
"out __SP_L__, r28 \n\t" \
"ld r29, x+ \n\t" \
"out __SP_H__, r29 \n\t" \
"pop r31 \n\t" \
"pop r30 \n\t" \
"pop r29 \n\t" \
"pop r28 \n\t" \
"pop r27 \n\t" \
"pop r26 \n\t" \
"pop r25 \n\t" \
"pop r24 \n\t" \
"pop r23 \n\t" \
"pop r22 \n\t" \
"pop r21 \n\t" \
"pop r20 \n\t" \
"pop r19 \n\t" \
"pop r18 \n\t" \
"pop r17 \n\t" \
"pop r16 \n\t" \
"pop r15 \n\t" \
"pop r14 \n\t" \
"pop r13 \n\t" \
"pop r12 \n\t" \
"pop r11 \n\t" \
"pop r10 \n\t" \
"pop r9 \n\t" \
"pop r8 \n\t" \
"pop r7 \n\t" \
"pop r6 \n\t" \
"pop r5 \n\t" \
"pop r4 \n\t" \
"pop r3 \n\t" \
"pop r2 \n\t" \
"pop r1 \n\t" \
"pop r0 \n\t" \
"out __SREG__, r0 \n\t" \
"pop r0 \n\t" \
* Perform hardware setup to enable ticks from timer 1, compare match A.
static void prvSetupTimerInterrupt( void );
* See header file for description.
portSTACK_TYPE *pxPortInitialiseStack( portSTACK_TYPE *pxTopOfStack, pdTASK_CODE pxCode, void *pvParameters )
unsigned short usAddress;
/* Place a few bytes of known values on the bottom of the stack.
This is just useful for debugging. */
*pxTopOfStack = 0x11;
pxTopOfStack--;
*pxTopOfStack = 0x22;
pxTopOfStack--;
*pxTopOfStack = 0x33;
pxTopOfStack--;
/* Simulate how the stack would look after a call to vPortYield() generated by
the compiler. */
/*lint -e950 -e611 -e923 Lint doesn't like this much - but nothing I can do about it. */
/* The start of the task code will be popped off the stack last, so place
it on first. */
usAddress = ( unsigned short ) pxCode;
*pxTopOfStack = ( portSTACK_TYPE ) ( usAddress & ( unsigned short ) 0x00ff );
pxTopOfStack--;
usAddress >>= 8;
pxTopOfStack--;
/* Next simulate the stack as if after a call to portSAVE_CONTEXT().
portSAVE_CONTEXT places the flags on the stack immediately after r0
to ensure the interrupts get disabled as soon as possible, and so ensuring
the stack use is minimal should a context switch interrupt occur. */
*pxTopOfStack = ( portSTACK_TYPE ) 0x00; /* R0 */
pxTopOfStack--;
*pxTopOfStack = portFLAGS_INT_ENABLED;
pxTopOfStack--;
/* Now the remaining registers. The compiler expects R1 to be 0. */
*pxTopOfStack = ( portSTACK_TYPE ) 0x00; /* R1 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x02; /* R2 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x03; /* R3 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x04; /* R4 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x05; /* R5 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x06; /* R6 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x07; /* R7 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x08; /* R8 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x09; /* R9 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x10; /* R10 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x11; /* R11 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x12; /* R12 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x13; /* R13 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x14; /* R14 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x15; /* R15 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x16; /* R16 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x17; /* R17 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x18; /* R18 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x19; /* R19 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x20; /* R20 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x21; /* R21 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x22; /* R22 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x23; /* R23 */
pxTopOfStack--;
/* Place the parameter on the stack in the expected location. */
usAddress = ( unsigned short ) pvParameters;
pxTopOfStack--;
usAddress >>= 8;
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x26; /* R26 X */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x27; /* R27 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x28; /* R28 Y */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x29; /* R29 */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x30; /* R30 Z */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) 0x031; /* R31 */
pxTopOfStack--;
/*lint +e950 +e611 +e923 */
return pxTopOfStack;
portBASE_TYPE xPortStartScheduler( void )
/* Setup the hardware to generate the tick. */
prvSetupTimerInterrupt();
/* Restore the context of the first task that is going to run. */
portRESTORE_CONTEXT();
/* Simulate a function call end as generated by the compiler. We will now
jump to the start of the task the context of which we have just restored. */
asm volatile ( "ret" );
/* Should not get here. */
return pdTRUE;
void vPortEndScheduler( void )
/* It is unlikely that the AVR port will get stopped. If required simply
disable the tick interrupt here. */
* Manual context switch. The first thing we do is save the registers so we
* can use a naked attribute.
void vPortYield( void ) __attribute__ ( ( naked ) );
portSAVE_CONTEXT();
vTaskSwitchContext();
* Context switch function used by the tick. This must be identical to
* vPortYield() from the call to vTaskSwitchContext() onwards. The only
* difference from vPortYield() is the tick count is incremented as the
* call comes from the tick ISR.
void vPortYieldFromTick( void ) __attribute__ ( ( naked ) );
portSAVE_CONTEXT();
vTaskIncrementTick();
* Setup timer 1 compare match A to generate a tick interrupt.
unsigned long ulCompareMatch;
unsigned char ucHighByte, ucLowByte;
/* Using 16bit timer 1 to generate the tick. Correct fuses must be
selected for the configCPU_CLOCK_HZ clock. */
ulCompareMatch = configCPU_CLOCK_HZ / configTICK_RATE_HZ;
/* We only have 16 bits so have to scale to get our required tick rate. */
ulCompareMatch /= portCLOCK_PRESCALER;
/* Adjust for correct value. */
ulCompareMatch -= ( unsigned long ) 1;
/* Setup compare match value for compare match A. Interrupts are disabled
before this is called so we need not worry here. */
ucLowByte = ( unsigned char ) ( ulCompareMatch & ( unsigned long ) 0xff );
ulCompareMatch >>= 8;
ucHighByte = ( unsigned char ) ( ulCompareMatch & ( unsigned long ) 0xff );
OCR1AH = ucHighByte;
OCR1AL = ucLowByte;
/* Setup clock source and compare match behaviour. */
ucLowByte = portCLEAR_COUNTER_ON_MATCH | portPRESCALE_64;
TCCR1A = ucLowByte;
/* Enable the interrupt - this is okay as interrupt are currently globally
disabled. */
ucLowByte = TIMSK1;
ucLowByte |= portCOMPARE_MATCH_A_INTERRUPT_ENABLE;
TIMSK1 = ucLowByte;
#if configUSE_PREEMPTION == 1
* Tick ISR for preemptive scheduler. We can use a naked attribute as
* the context is saved at the start of vPortYieldFromTick(). The tick
* count is incremented after the context is saved.
void SIG_OUTPUT_COMPARE1A( void ) __attribute__ ( ( signal, naked ) );
vPortYieldFromTick();
asm volatile ( "reti" );
#else
* Tick ISR for the cooperative scheduler. All this does is increment the
* tick count. We don't need to switch context, this can only be done by
* manual calls to taskYIELD();
void SIG_OUTPUT_COMPARE1A( void ) __attribute__ ( ( signal ) );
no it is a simple ATmega(without X)1284
the ports of this microcontroller are the same as by ATmega32 however there are sone differences in registres of Timer 1 which is used by tick interrupts.
i dont know what should i change , i mean which registers, in the port.c file to configure Timer 1 of my ATmega.
with old configuration it doent work.
…/…/…/…/Source/tasks.c: In function ‘xTaskGenericCreate’:
…/…/…/…/Source/tasks.c:523: warning: cast from pointer to integer of different size
…/…/…/…/Source/tasks.c:523: warning: cast to pointer from integer of different size
avr-gcc -I"D:\Install\FreeRTOSV7.3.0\FreeRTOS\Projects\SUMO\FreeRTOSmain\…\…\…\Source\include" -I"D:\Install\FreeRTOSV7.3.0\FreeRTOS\Projects\SUMO\FreeRTOSmain\…\…\…\Source\portable\GCC\ATMega323" -I"D:\Install\FreeRTOSV7.3.0\FreeRTOS\Projects\SUMO\F
reeRTOSmain\." -mmcu=atmega1284p -Wall -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT heap_2.o -MF dep/heap_2.o.d -c …/…/…/…/Source/portable/MemMang/heap_2.c
Where are the constants OCR1AH, OCR1AL, TCCR1A and TIMSK1 coming from? There must a header file somewhere that defines these. Is the header file specific to the original chip that works? If so, maybe switching the header file to be right for your new chip will solve the problem. If you are using IAR you should be able to highlight the constant then right click and select “go to definition” from the pop up menu (are you using IAR?). Also if you are using IAR, have you re-targeted the project for the new chip?
edwards3, i am using GCC
i havent got any header file for ports…i thought i should only change something in port.c file
at the link above i have only found port.c which i only added to my project; the old is deleted
../../../../Source/portable/GCC/ATMega323/port.c:445: warning: 'SIG_OUTPUT_COMPARE1A' appears to be a misspelled signal handler
Either the signal handler syntax needs to change (this is a very old FreeRTOS port and could use obsolete syntax, although you said the 32 build ran ok), or there is no such signal on the new chip.
asm volatile ( “reti” );
} #else
* tick count. We don’t need to switch context, this can only be done by
} #endif
with this one=)
It works=)
edwards3, thank you very much=)
thank you all who tried to help=)
void TIMER1_COMPA_vect( void ) __attribute__ ( ( signal, naked ) );
} #else
void TIMER1_COMPA_vect( void ) __attribute__ ( ( signal ) );
} #endif
