AT32UC3B Build problems
hhumberto wrote on Friday, January 16, 2015:
Hi!..I have problems when trying to compile at32uc3b demo project.
I have this screen:
Warning: Deprecated arch `uc’ specified. Please use ‘-march=ucr1’ instead. Using arch ‘ucr1’
…/…/BOARDS/EVK1101/led.c:46:22: error: avr32/io.h: No such file or directory
In file included from …/…/BOARDS/EVK1101/led.c:50:
…/…/BOARDS/EVK1101/led.h:68: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display’
…/…/BOARDS/EVK1101/led.h:76: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.h:86: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display_Mask’
…/…/BOARDS/EVK1101/led.h:96: error: expected ‘)’ before ‘mask’
…/…/BOARDS/EVK1101/led.h:107: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Test’
…/…/BOARDS/EVK1101/led.h:115: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.h:123: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.h:131: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.h:143: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display_Field’
…/…/BOARDS/EVK1101/led.h:153: error: expected ‘)’ before ‘field’
…/…/BOARDS/EVK1101/led.h:167: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Get_Intensity’
…/…/BOARDS/EVK1101/led.h:179: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.c:58: error: expected specifier-qualifier-list before ‘U32’
…/…/BOARDS/EVK1101/led.c:63: error: expected specifier-qualifier-list before ‘S32’
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PIN_PA07’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: warning: excess elements in struct initializer
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[0].GPIO’)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[0].PWM’)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PWM_PWM_0_0_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PIN_PA08’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[1].GPIO’)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[1].PWM’)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PWM_PWM_1_0_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PIN_PA21’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[2].GPIO’)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[2].PWM’)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PWM_PWM_2_0_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PIN_PA22’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[3].GPIO’)
…/…/BOARDS/EVK1101/led.c:77: warning: (near initialization for ‘LED_DESCRIPTOR[3].PWM’)
…/…/BOARDS/EVK1101/led.c:77: error: ‘AVR32_PWM_PWM_6_0_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1101/led.c:83: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_State’
…/…/BOARDS/EVK1101/led.c:86: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display’
…/…/BOARDS/EVK1101/led.c:92: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.c:119: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display_Mask’
…/…/BOARDS/EVK1101/led.c:125: error: expected ‘)’ before ‘mask’
…/…/BOARDS/EVK1101/led.c:155: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Test’
…/…/BOARDS/EVK1101/led.c:161: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.c:182: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.c:203: error: expected ‘)’ before ‘leds’
…/…/BOARDS/EVK1101/led.c:224: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Read_Display_Field’
…/…/BOARDS/EVK1101/led.c:230: error: expected ‘)’ before ‘field’
…/…/BOARDS/EVK1101/led.c:236: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘LED_Get_Intensity’
…/…/BOARDS/EVK1101/led.c:251: error: expected ‘)’ before ‘leds’
Makefile:559: recipe for target ‘…/…/BOARDS/EVK1101/led.o’ failed
make: *** […/…/BOARDS/EVK1101/led.o] Error 1
rtel wrote on Saturday, January 17, 2015:
I suspect most of your problems will relate the the first error:
“…/…/BOARDS/EVK1101/led.c:46:22: error: avr32/io.h: No such file or directory”
However, note the UC3 port is old, and only works on old revisions of UC3 chips. Your best bet is to take a demo from http://asf.atmel.com
Note the “legacy issues” section of this page: http://www.freertos.org/a00104.html
