kamejoko80 wrote on Monday, February 20, 2017:
Hello everyone,
Regarding to ARM cortex-a9 porting, I see the IRQ handler as below code :
FreeRTOSv9.0.0\FreeRTOS\Source\portable\GCC\ARM_CA9\portASM.S
.align 4
.type FreeRTOS_IRQ_Handler, %function
FreeRTOS_IRQ_Handler:
/* Call the interrupt handler. */
PUSH {r0-r3, lr}
LDR r1, vApplicationIRQHandlerConst
BLX r1
POP {r0-r3, lr}
ADD sp, sp, r2
CPSID i
DSB
ISB
This code intends to allow nested interrupt but IRQ enable instruction “CPSID i” is bellow application IRQ handler, I think this is not correct. In order to higher priority IRQ can preamt lower priority IRQ, IRQ enable instruction should be placed before application IRQ handler.
/* save registers */
PUSH {r0-r3, lr}
CPSID i
DSB
ISB
BLX r1
POP {r0-r3, lr}
ADD sp, sp, r2
Please correct me if I’m wrong.
Thanks and Best Regards,
Phuong Dang
