sterossi84 wrote on Friday, November 23, 2018:
Hi Guys,
I’m working on dual-core ZYNQ equipped with FreeRTOS v10.1.1.
I would like to disable interrupt nesting capability but I still need to assign a priority to interrupt.
The idea is that, if an interrupt is being serviced and other interrupts becomes pending in GIC controller, the next IRQ to be serviced soon after current ISR completes is the one pending with highest priority .
looking at FreeRTOS port I think this is possible by moving the interrupt re-enable instruction after servicing the interrupt.
Is this correct? Does it leads to some problems?
Thanks in advance
Bucky
void vApplicationFPUSafeIRQHandler( uint32_t ulICCIAR )
extern const XScuGic_Config XScuGic_ConfigTable[];
static const XScuGic_VectorTableEntry *pxVectorTable = XScuGic_ConfigTable[ XPAR_SCUGIC_SINGLE_DEVICE_ID ].HandlerTable;
uint32_t ulInterruptID;
const XScuGic_VectorTableEntry *pxVectorEntry;
/* Original Code below */
#if 0
/* Re-enable interrupts. */
__asm ( "cpsie i" );
/* The ID of the interrupt is obtained by bitwise anding the ICCIAR value
with 0x3FF. */
ulInterruptID = ulICCIAR & 0x3FFUL;
if( ulInterruptID < XSCUGIC_MAX_NUM_INTR_INPUTS )
/* Call the function installed in the array of installed handler functions. */
pxVectorEntry = &( pxVectorTable[ ulInterruptID ] );
pxVectorEntry->Handler( pxVectorEntry->CallBackRef );
#if 1 /* My Modification */
