me@pc:~/amazon-freertos/demos/espressif/esp32_devkitc_esp_wrover_kit/make$ make flash
Here is the make response:
Toolchain path: /home/me/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
Python requirements from /home/me/esp/esp-idf/requirements.txt are satisfied.
CC build/amazon-freertos-common/lib/tls/aws_tls.o
In file included from /home/me/amazon-freertos/demos/espressif/esp32_devkitc_esp_wrover_kit/common/config_files/FreeRTOSConfig.h:40:0,
from /home/me/amazon-freertos/lib/include/FreeRTOS.h:56,
from /home/me/amazon-freertos/lib/tls/aws_tls.c:27:
/home/me/esp/esp-idf/components/esp32/include/rom/ets_sys.h:1:2: warning: #warning rom/ets_sys.h is deprecated, please use esp32/rom/ets_sys.h instead [-Wcpp]
In file included from /home/me/amazon-freertos/lib/third_party/mbedtls/include/mbedtls/aes.h:111:0,
from /home/me/amazon-freertos/lib/third_party/mbedtls/include/mbedtls/ctr_drbg.h:36,
from /home/me/amazon-freertos/lib/tls/aws_tls.c:40:
/home/me/amazon-freertos/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/mbedtls/port/include/aes_alt.h:31:26: fatal error: hwcrypto/aes.h: No such file or directory
compilation terminated.
/home/me/esp/esp-idf/make/component_wrapper.mk:289: recipe for target 'lib/tls/aws_tls.o' failed
make[1]: *** [lib/tls/aws_tls.o] Error 1
/home/me/esp/esp-idf/make/project.mk:578: recipe for target 'component-amazon-freertos-common-build' failed
make: *** [component-amazon-freertos-common-build] Error 2
What am I doing wrong?
Edited by: EugeneFromDigiVac on Apr 4, 2019 8:14 PM
Can you please check if IDF_PATH is set somewhere in your source tree? If it is, it will not point to lib/third_party/mcu_vendor/espressif/esp-idf
In makefile for demos: (demos/espressif/esp32_devkitc_esp_wrover_kit/make/Makefile) we define IDF_PATH as follows:
So if you have IDF_PATH defined somewhere else, you will start seeing compilation problems.
We are using latest master to make sure build works.
I am experiencing following error while building mqtt demo project for esp32. I tried clearing IDF_PATH by unset IDF_PATH millions of times . Any insight ?
Building partitions from /d/amfrtos/demos/espressif/esp32_devkitc_esp_wrover_kit/make/partitions_example.csv…
CC build/amazon-freertos-common/lib/mqtt/aws_mqtt_agent.o
In file included from D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:47:0:
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c: In function ‘prvSetupConnection’:
D:/amfrtos/lib/include/aws_secure_sockets.h:339:37: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers] #define socketsAWS_IOT_ALPN_MQTT “x-amzn-mqtt-ca”
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:859:27: note: in expansion of macro ‘socketsAWS_IOT_ALPN_MQTT’
char * ppcAlpns[] = { socketsAWS_IOT_ALPN_MQTT };
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c: In function ‘MQTT_AGENT_Init’:
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:1907:25: error: implicit declaration of function ‘xQueueCreateStatic’ [-Werror=implicit-function-declaration]
xCommandQueue = xQueueCreateStatic( mqttCOMMAND_QUEUE_LENGTH, sizeof( MQTTEventData_t ), ucQueueStorageArea, &xStaticQueue );
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:1907:23: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:1910:27: error: implicit declaration of function ‘xTaskCreateStatic’ [-Werror=implicit-function-declaration]
xMQTTTaskHandle = xTaskCreateStatic( prvMQTTTask, “MQTT”, mqttconfigMQTT_TASK_STACK_DEPTH, NULL, mqttconfigMQTT_TASK_PRIORITY, xStack, &xStaticTask );
D:/amfrtos/lib/mqtt/aws_mqtt_agent.c:1910:25: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
cc1.exe: some warnings being treated as errors
make[1]: *** [/d/amfrtos/lib/third_party/mcu_vendor/espressif/esp-idf/make/component_wrapper.mk:286: lib/mqtt/aws_mqtt_agent.o] Error 1
make: *** [/d/amfrtos/demos/espressif/esp32_devkitc_esp_wrover_kit/make/…/…/…/…/lib/third_party/mcu_vendor/espressif/esp-idf/make/project.mk:477: component-amazon-freertos-common-build] Error 2
If you are still in the prototyping stage, please consider upgrading to the latest Amazon FreeRTOS in GitHub master. The MQTT library has been rewritten since your original post.
