Just looking for a little advice on memory allocation.
I am using an STM32H7 processor with ITCM and DTCM ram. I am looking for speed and so I wish to put critical code in ITCM and critical data in DTCM.
I am setting up the MPU outside of the operating system and don’t wish to use FreeRTOS MPU features.
I had a look at the mpu_wrappers.h file and noticed the following code:
#define PRIVILEGED_FUNCTION
#define PRIVILEGED_DATA
#define FREERTOS_SYSTEM_CALL
#define portUSING_MPU_WRAPPERS 0
I figured that if I do the following in this file then functions would be placed in ITCM and data would be placed in DTCM.
#define USE_DTCM __attribute__((section (".DTCM_MISC")))
//#define USE_DTCM
#define USE_ITCM __attribute__((section(".ITCM_SECTION")))
//#define USE_ITCM
#define PRIVILEGED_FUNCTION USE_ITCM
#define PRIVILEGED_DATA USE_DTCM
Where .ITCM_MISC and .DTCM_MISC are the definitions for the two memory regions as defined in the GCC linker script.
Is this method going to achieve my objective?
Is there a better way of doing it? In other words what would a real programmer do not a hacker like me?
Best regards
Rob
