We still use the vTaskDelayUntil but we are not able to go under 8/7ms.
Maybe we need to assign the task to the core1?
Or what can limit our task to 7/8ms?
static void yys_rtc_task(void* arg)
static int64_t time = 0;
static int64_t endTime = 0;
static int64_t deltaT = 0;
static TickType_t xLastWakeTime;
static const TickType_t xFrequency = 7;
static BaseType_t xWasDelayed;
// Initialise the xLastWakeTime variable with the current time.
xLastWakeTime = xTaskGetTickCount();
for (;;)
time = esp_timer_get_time();
deltaT = time – endTime;
endTime = time;
// Wait for the next cycle.
//xWasDelayed = xTaskDelayUntil(&xLastWakeTime, xFrequency);
vTaskDelayUntil(&xLastWakeTime, xFrequency);
// time = esp_timer_get_time();
// deltaT = time – endTime;
// endTime = time;
// Perform action here. xWasDelayed value can be used to determine
// whether a deadline was missed if the code here took too long.
ESP_LOGE(“TEST”, “time %lld — deltaT %lld — xWasDelayed %d”, time, deltaT, xWasDelayed);
What is the frequency of the tick interrupt, and have you verified you are actually getting the tick frequency you think you are? The delay time is specified in ticks so only has a resolution of the tick frequency.
To add a little to aggarg@'s reply. A 500Hz frequency (2ms period) means requesting to block for 4ms can result in a block time of 3.0001 (if the block starts immediately before the next tick interrupt) to 3.99999ms (if the block starts immediately after the last tick interrupt) because you have a 2ms resolution.
If you need to run at an exact interval, then it sounds like you should be doing this task from an ISR.
I’m not 100% sure on the determinism of waking up a task, but an alternative idea would be for the task to wait on a notification sent from the tick ISR, so no sleeps would be involved. Your task would have to have a high priority as well so you’d wake it up immediately after the ISR ends by calling portYIELD_FROM_ISR. You can read about notifications here.
