Yet another question (PIC18 MPLAB port)
el_es wrote on Thursday, August 14, 2008:
Starting a new thread, because this is generally about the PIC18F MPLAB port.
I admit, my assembly language understanding (of PIC assembler that is) is less than satisfactory - but here is what I spotted :
in FreeRTOS\Source\portable\MPLAB\PIC18F\port.c
in portRESTORE_CONTEXT() macro :
----- line 273
    /* How many return addresses are there on the hardware stack?  Discard
        the first byte as we are pointing to the next free space. */
        MOVFF    POSTDEC1, FSR0L
    _endasm
    /* Fill the hardware stack from our software stack. */
    STKPTR = 0;
    while( STKPTR < FSR0L )            <<<<< this
        _asm
------- line 284
I understand that the STKPTR is just a counter that can be 0…31.
Whereas the FSR0{L,H} are the lower and higher byte of the pointer.
I suppose the line marked  <<<<< this
should rather read
     while(STKPTR < INDF0)
to have the STKPTR compared with the count of addresses that were saved on stack, and NOT the address it is saved at ?
Am I right or should I learn more PIC18 assembler ? :slight_smile:
rtel wrote on Friday, August 15, 2008:
I think - again from memory - that FSR0L contains the number of items that need pushing onto the hardware stack.
portSAVE_CONTEXT() moves the hardware stack onto the task stack - the number of items that were on the hardware stack is variable so portSAVE_CONTEXT() also pushes the number of items that the hardware stack contained onto the task stack.  When portRESTORE_CONTEXT is called it loads this number from the task stack into FSR0L - then uses this number as a loop counter as it moves the items back from the task stack into the hardware stack - ensuring that the right number of items are restored.
A bit ugly, but this is constrained by how the PIC18 and the C18 compiler both work.
el_es wrote on Friday, August 15, 2008:
(Yay, The Author Himself spoke to me :slight_smile: )
So it actually does, you’re right - it is even written in the commentary :slight_smile:
I’m just concerned about the point of using FSR0L to hold the simple counter value.
Any rationale behind this ? Why not simply use the WREG here ? Or some other memory field (not to search too far - the code that pops the task context back:
— line 273
+/* Use WREG to hold this value */
-            MOVFF    POSTDEC1, FSR0L
+              MOVF POSTDEC1                  /* this is one cycle less and one program word less also */
+              MOVF POSTDEC1                  /* we have the stack level in the WREG now */
    _endasm
    STKPTR = 0;
-    while( STKPTR < FSR0L )
+      while(STKPTR < WREG)      /* no idea how would this compile ?*/
+/* might actually need to be asm-coded - but could it have a point being shorter->faster? */
— line 283
Provided the value of that register is restored from that task stack after it is used as the counter (if it were before then its value would get clobbered) then I don’t see why not :o)
Yes,
—  port.c, line 353
        _asm
            MOVFF    POSTDEC1, STATUS
            MOVFF    POSTDEC1, WREG
            /* Return without effecting interrupts.  The context may have
            been saved from a critical region. */
            RETURN    0
        _endasm
— port.c, line 359
this is the very last register restored in context restore.
So this actually could work :slight_smile: provided, that C18 doesn’t f* up the WREG compiling the while() loop…
(I’m just analyzing the code till now - didn’t try to compile&see yet - if somebody verified that works I’d be glad)
If it does, bad luck then… we’ll need to code the stack restoration in asm fully.
(but hey, this is port code anyway, and port*CONTEXT are macros)
paul_piak wrote on Thursday, October 02, 2008:
The thing is that the restore code inside the while loop is:
            MOVF    POSTDEC1, 0, 0
            MOVWF    TOSU, 0
            MOVF    POSTDEC1, 0, 0
            MOVWF    TOSH, 0
            MOVF    POSTDEC1, 0, 0
            MOVWF    TOSL, 0
thus WREG is compromised by the restore instructions themselves. Therefore "while(STKPTR < WREG)"
will not work.
You might want to suggest to use the following code instead (just like the stack-save code, not using WREG)
            MOVFF    POSTDEC1,TOSU
            MOVFF    POSTDEC1,TOSH
            MOVFF    POSTDEC1,TOSL
but this  is illegal:
Error - file ‘./SERIAL.o’, section ‘.code_SERIAL.o’, TOSU cannot be used as the destination of a MOVFF or MOVSF instruction.
Paul
