antoniodefina wrote on Wednesday, May 22, 2013:
I all,
My name is Antonio. I have a problem with standard I\O functions, in particular with sscanf function. I use Free RTOS on SAM7X micro controller compiled with yagarto tool chain (version 4.7.2). The problem is that sometimes the sscanf does not provide in output the values. For example:
char message;
int returnScanf;
int getValue;
strcpy(message,“2”);
getValue = 5;
returnScanf = sscanf(message,"%d",&getValue);
//returnScanf is equal to 1 (correct), but getValue is equal to 0
It is very strange, because sometimes, if I try to compile again the same source code, it sometimes works properly (without changing any header\compiler option, etc.).
I use this compiler options:
COMPILER_GENERAL_OPTIONS= \
-mthumb-interwork \
-mcpu=arm7tdmi \
-T$(LDSCRIPT) \
-Wall \
-g \
-O1\
-fomit-frame-pointer \
-fno-dwarf2-cfi-asm
and linker options:
LINKER_FLAGS=-nostartfiles -Xlinker -o$(PROJECTNAME).$(ARMEXT) -lm -Xlinker -M -Xlinker -Map=$(PROJECTNAME).$(MAPEXT)
Could you please help me to find the possible mistake?
Thanks in advance
