typedef struct SemaphoreDefinition {
int count;
xList xTasksWaitingToTake;
}xSEMAPHORE ;
in my SemaphoreGive() ,
i need to extract highest priority task from xTasksWaitingToTake list
does xTaskRemoveFromEventList(xTasksWaitingToTake) really remove highest priority task from my semaphore event list, remove it from delayed/overflow delayed list and put it in ready list?
I just cant find an example of it in FreeRTOS itself. xQueueSend/Receive doesnt seem to be using this function.
xTaskRemoveFromEventList is used from queue.c. The normal way to implement a counting semaphore is to use a queue in the same way that the binary semaphore does, but with more than one space on the queue. No data is actually queued as the data size is set to zero.
yeah, but I am supposed to do some study of difference between semaphore with dedicated structure, and semaphore using queue structure like FreeRTOS’s.
does FreeRTOS provide facility to extract highest priority task from event list?
