That code looks like it should work, but if you check the stack trace you might be able to figure out who is giving up the mutex when it didn’t have it.
Even with a delay of portMAX_DELAY, I always check the return value of the take to make sure it was successful, and my most typical usage would be something like:
if(xSemaphortTake(handle, delay)) {
// Code for handling the successful take
xSemaphoreGive(handle);
As this structure provides a positive guard for the usage. Sometime this structure doesn’t fit what the program is doing, but I still will always check the success.
The assertion you are hitting is indicating that someone who doesn’t currently own the mutex is trying to give it.
It is also possible you have an interrupt priority issue that cause program problems, 8.2.1 may be old enough that it may be missing some of the checks.
Yes - would recommend updating to a newer version then ensuring configASSERT() is defined. If you are using a Cortex-M the later the version the more programmatic checks there are. In any case I would recommend reading through this: FreeRTOS - Open Source RTOS Kernel for small embedded systems
Just a quick note to say thanks! I did not know that. I thought xSemaphoreGive() would return pdFAIL for that case. And two of my own APIs were affected. My functions spi_close() and i2c_close() are written to tolerate a user calling them unnecessarily. I had comments in each one that said “we don’t need to bother verifying that the current task is the mutex owner since FreeRTOS verifies that for us”. Oops!
