I just did some quick measurements and noticed that from the moment a task of lower priority sends a xTaskNotify() notification to the only task of higher priority, it takes 44.4us on a 32bit PIC running at 200MHz. That is 8,880 cycles… (I corrected this as I initially thought it was 4 cycles / instruction) but just found out it is not because of pipelining) this unrealistically long…
I already had configUSE_PREEMPTION set to 1 so I assume adding taskYield() in the line immediately after it would not make any difference, just to be sure, is that correct?
I also did try adding adding taskYield() immediately after but it made no difference…
In order to make it switch immediately, what do I need to do?
are you absolutely sure that no higher priority interrupt kicks in between the xTaskNotify() and the take? Best would be a deep trace; alternatively, can you use Tracealyzer?
I checked and no other task has higher priority. All other tasks are priority 1 and there is only 1 task at priority 3.
What else could it be?
@rtel, you mention that PIC32 is probably longer. To me 8,880 cycles (I just updated the value mentioned in the OP which I incorrectly put to 2,200) for a context switch following a notification still seem way too much. But being a newbie that might be completely wrong. So just so I know, to get a feel for it, would it be generally possible for it to takes 8,880 instructions?
I found what it was. There was a “fast” logging function which was supposed to be only few cycles but when looked at the code it turned out to be quite lengthy.
