I am using a at91sam7s arm7 chip, with IAR toolchain and 4.5.0 freeRTOS.
I notice in definition of xTaskGetTickCount that the rturn of the count is surrouded by taskENTER_CRITICAL/taskEXIT_CRITICAL with the comment
/* Critical section required if running on a 16 bit processor. */
Presumably since the ARM is 32 bits, I can replace this with a simple return xTickCount? Can I ‘automate’ this by using the #if (sizeof(portBASE_TYPE) >= 4) or is this likely to fail somewhere else?
Hmm I find that IAR won’t accept sizeof as a preprocessor command! Keep looking!
If the definition of portTickType is the natural size of the processor word size (portTickType == portBASE_TYPE in effect), then the enter/exit critical is not required. Removing the enter/exit critical also allows the function to be called from an ISR. You could of coarse just set the tick count variable to be global, if you don’t mind doing that sort of thing.
I prefer to keep other fingers out of this, by hiding it, but resent the time taked to post the critical flags if not necessary!
Presumably the same applies to prvIsQueueEmpty, uxQueueMessagesWaiting and uxTaskGetNumberOfTasks, and also possibly prvIsQueueFull() as pxQueue->uxLength is set when the queue is set up, and cannot be dynamically changed.
Be careful with the queue functions. prvIsQueueEmpty() and prvIsQueueFull() make a comparison, which is not atomic, so could require the critical section even though the comparison is with a constant - this depends on the code generated, it also depends on whether getting a result which for an instant is out of date really matters (which it probably doesn’t). uxQueueMessagesWaiting(), uxTaskGetNumberOfTasks() should be ok.
