hoedur wrote on Tuesday, April 19, 2011:
this time a not so stupid question (hopefully)
I know there are not so many people out there usinf Fujitsu MCUs, but perhaps did somebody experience similar behavior with another MCU and has an idea how to solve this problem.
I am working with a Fujitsu FX MCU (the M96F348HSB). Currently I am implementing a few test tasks to see if FreeRTOS is working properly. I have one task that toggles an LED every 3000 ms (BlinkTaskSlow), another task toggles another LED every 1000 ms (BlinkTaskFast).
I expected such a behavior (0 means LED off, 1 means LED on):
BlinkTaskSlow: 000111000111...
BlinkTaskFast: 010101010101...
But they behave like this:
BlinkTaskSlow: 000111000001110000011100000111...
BlinkTaskFast: 010101010101010101010101010101...
The tasks are implemented as follows:
void vBlinkTaskSlow(void * pvParameters)
portTickType xLastWakeTimeSlow = 0;
portTickType xFrequencySlow = 3000 / portTICK_RATE_MS;
xLastWakeTimeSlow = xTaskGetTickCount();
for(;;) {
vTaskDelayUntil( &xLastWakeTimeSlow, xFrequencySlow );
PDR06_P0 = ~PDR06_P0; /* this toggles a LED */
void vBlinkTaskFast(void * pvParameters)
portTickType xLastWakeTimeFast = 0;
portTickType xFrequencyFast = 1000 / portTICK_RATE_MS;
xLastWakeTimeFast = xTaskGetTickCount();
for(;;) {
vTaskDelayUntil( &xLastWakeTimeFast, xFrequencyFast );
PDR06_P2 = ~PDR06_P2; /* this toggles a LED */
The tasks are started within the main() function:
xTaskCreate(
vBlinkTaskSlow,
( signed char * ) "BlinkTaskSlow",
configMINIMAL_STACK_SIZE,
NULL,
tskIDLE_PRIORITY + 2,
&xBlinkTaskSlowHandle);
xTaskCreate(
vBlinkTaskFast,
( signed char * ) "BlinkTaskFast",
NULL,
tskIDLE_PRIORITY + 3,
&xBlinkTaskFastHandle);
Even if I only start BlinkTaskSlow, this tasks toggles its LED not regularly (it is switched on 3000 seconds, then it is turned off for 5000 seconds).
I tried to change the priorities of the tasks, but it does’nt matter whether BlinkTaskSlow or BlinkTaskFast has the higher priority. Even if both have the same priority they behave as described.
I also implemented a tick hook function to see if the tick is generated correctly. The implementation of the tick hook function is:
void vApplicationTickHook( void )
static portTickType xHookTickCount = 0;
if ( ( xHookTickCount % ( 3000 / portTICK_RATE_MS ) ) == 0 ) {
PDR03_P3 = ~PDR03_P3;
xHookTickCount = 0;
xHookTickCount++;
This function should toggle another LED in the same frequency as BlinkTaskSlow should do. Surprisingly the hook function toggles its LED exactly in the same was as BlinkTaskSlow (000111000001110000011100000 instead of 000111000111000111).
I had a closer look at the hook function and monitored the LED with an oscilloscope. I recognied that the LED is toggled two times within its 5000 ms off-phase. The interval between the two toggles is 4,00 ms, which is two times the Tick frequency I use (500 Hz).
The tick frequency is correct. I inserted a port toggle at the top of the Interrupt Service Routine that creates the tick and measured the toggle frequency with an oscilloscope. Only at the point where the two 4,00 ms toggles (mentioned above) occur, the tick is stopped for that period of time.
The FreeRTOSConfig.h is set up as follows:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
/* Device specific includes. */
#include "mb96348hs.h"
* The below define should be same as the option selected by the Memory
* Model (Project->Setup Project->C Compiler->Category->Target Depend )
* Valid settings here include:
* ------- Memory models --------- Data Code
* portSMALL 16 Bit 16 Bit
* portMEDIUM 16 Bit 24 Bit
* portCOMPACT 24 Bit 16 Bit
* portLARGE 24 Bit 24 Bit
#define configMEMMODEL portMEDIUM
/* Demo specific definition - set this to 1 if you want to include the task
that writes trace and debug information to the UART. If it is set to 0 then
the ComTest tasks will be included in place of the trace task. */
#define INCLUDE_TraceListTasks 0
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
#define configUSE_IDLE_HOOK 0 /* 1 by default */
#define configUSE_TICK_HOOK 1
#define configUSE_MALLOC_FAILED_HOOK 1
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 180 ) /* This can be greatly reduced when using the small or medium memory model. */
#define configCPU_CLOCK_HZ ( ( unsigned long ) 48000000 ) /* Clock setup from start.asm in the demo application. */
#define configCLKP1_CLOCK_HZ ( ( unsigned long ) 48000000 ) /* Clock setup from start.asm in the demo application. */
#define configTICK_RATE_HZ ( (portTickType) 500 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 6 )
#define configTOTAL_HEAP_SIZE ( (size_t) (3000) ) /* was 20000 before */
#define configMAX_TASK_NAME_LEN ( 20 )
#define configUSE_MUTEXES 1
#define configUSE_TRACE_FACILITY 0 /* 1 by default */
#define configCHECK_FOR_STACK_OVERFLOW 1 /* 0 by default */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 2)
#define configTIMER_QUEUE_LENGTH 5
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE )
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 ) /* 4 by default */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 1
#define INCLUDE_vResumeFromISR 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTaskGetCurrentTaskHandle 1
#define configKERNEL_INTERRUPT_PRIORITY 6
Does anybody have an idea what is going wrong there?
Thanks in advance for your help!
