HI, i have a random crash on my esp32 s3 linked to the btc_task
xt_lowint1 () at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/freertos/port/xtensa/xtensa_vectors.S:1079
Looking for further information about this error please.
Thanks
Thanks
Hi @terrafirma2021,
Could you help provide more information?
Like what esp-idf version you’re using? And any other call stacks available?
BTW, could you please check if configASSERT is defined to catch problem in early stage and configCHECK_FOR_STACK_OVERFLOW is defined to check if stack overflow happened?
Thank you.
Thank you for the reply, I did some further investigations into this as the crashes seem to be more frequent even when rolling back to an early build.
I looked at my backtrace and i was seeing UART related bugs also
The issue ended up being a driver issue related to the zadig, when GDB was installed,
Issue is resolved now!
Thanks for your time
Thanks for your feedback!
