leviatan1 wrote on Wednesday, August 06, 2014:
Hello, i have this dspic30F project im using interrupts from uart module, i have organized my projec into 3 files. “main.c” “subfunctions.c” and “subfunctions.h”
The problem i have is that one task should be unblocked from the RX UART ISR taking a binary semaphore, but it seems to take the semaphore and unblock even if the semaphore in not “given”.
i will put the code regarding the malfunction only, i have no warnings or errors.
main.c:
/******************Semaphores and Task Handles****************/
xSemaphoreHandle Mutex_I2C_Rx = 0;
xSemaphoreHandle Mutex_I2C_Tx = 0; //viejo
SemaphoreHandle_t Sem_Ctrl = 0; //nuevo
xTaskHandle I2C_HANDLE;
xTaskHandle I2C_RX;
xTaskHandle I2C_TX;
int main( void )
{ prep_HARD();
/* Create the standar Queues*/
Queue_I2C_DataHander = xQueueCreate(5, sizeof(unsigned char));
Queue_I2C_ACK = xQueueCreate(3, sizeof(unsigned char));
/* Create standard Semaphores and Mutexes*/
Mutex_I2C_Rx = xSemaphoreCreateMutex();
Mutex_I2C_Tx = xSemaphoreCreateMutex();
vSemaphoreCreateBinary(Sem_Ctrl); //xSemaphoreCreatBinary WONT WORK GIVES ERROR
/* Create the standard tasks. */
xTaskCreate(data_I2C_HANDLE,"Handle I2C",128,NULL,4,&I2C_HANDLE);
xTaskCreate(rx_I2C,"Recepcion SPI",128,NULL,5,&I2C_RX);
xTaskCreate(tx_I2C,"Transmision SPI",128,NULL,3,&I2C_TX);
/* Finally start the scheduler. */
vTaskStartScheduler();
/* Will only reach here if there is insufficient heap available to start
the scheduler. */
return 0;
Subfunctions.h
INTERRUPT ROUTINE:
//INTERRUPCION RX UART
void _ISRFASTPSV _U1RXInterrupt()
IFS0bits.U1RXIF = 0; //LIMPIO FLAG
xSemaphoreGiveFromISR(Sem_Ctrl,NULL);
TASK THAT SHOULD BE BLOCKED BUT SOMETIMES IT JUST GET THE SEMAPHORE WHEN INTERRUPT HAS NOT OCCURRED:
void rx_I2C(void *pvParameters)//Task receiving I2C data
//Variables que usa la Funcion INTERNAMENTE A LA TAREA
int i;
while(1)
//Esta tarea espera el mutex para poder usar la queue
//Funcion que lee el buffer I2C
if(xSemaphoreTake(Sem_Ctrl, portMAX_DELAY))
//usRx_data = ReadUART1();
vTaskDelay(500/portTICK_RATE_MS);
if(U1STAbits.OERR ==1)
U1STAbits.OERR = 0;
vTaskDelay(10);
//El codigo siguiente es en caso que la tarea salga del for
//si esto pasa la tarea se borra
vTaskDelete(NULL);
ADDITIONAL INFORMATION: EVERY TIME DATA ENTERS DE UART RX AN INTERRUPT IS GENERATED WHILE SIMULATING SOMETIMES Y RE-ENTER THE INTERRUPT 3 TIMES, WOULD THIS MAKE 3 SEMAPHORES AVAILABLE? EVEN IF MY SEMAPHORE ISN’T A COUNTING SEMAPHORE?
Should i use another method? should i use port yield from ISR? Which is the correct function for YIELD fromISR for dspic?
Any help is very apreciated thank you very much!
