xSemaphoreGiveFromISR failed?
I’m using freertos 8.2.3, and I meet a problem of xSemaphore.
I used xSemaphore successful in one of my project. but when I use it the same way in another project, it failed to give semaphore. the latter project is derived from the former one. and I compared FreeRTOSConfig.h in the two project, they are the same.
the program stopped at xSemaphoreGiveFromISR. any other factor can influence semaphore?
the way I use xSemaphore is like this:
in .h file
    SemaphoreHandle_t data_ready_sem;
in .c file
in one function:
data_ready_sem = xSemaphoreCreateBinary();
if( data_ready_sem == NULL ){
	ERROR_RESIN("data_ready_sem create failed\r\n");
// init some variable
xSemaphoreTake(data_ready_sem, portMAX_DELAY);
in timer fired handler:
    xSemaphoreGiveFromISR(data_ready_sem, &xHigherPriorityTaskWoken2);
What do you mean with a “timer fired handler”? Is that a hardware timer causing an ISR?
Or is that a handler that is called from the timer module?
And if so, I think you should use xSemaphoreGive() because the code runs in the context of the timer task.
Maybe the code stops in a configASSERT(), have you checked that?
That version works perfectly, but it is recommended to use the latest version for new developments.
Hi, Hein Tibosch
Thanks for your reply.
I tried xSemaphoreGive() and it stopped at xSemaphoreTake(data_ready_sem, portMAX_DELAY);
I dig into xSemaphoreTake and find it stopped at ‘portYIELD_WITHIN_API();’
I’ll dig into xSemaphoreGiveFromISR and try to find where the program stops.
if I use xSemaphoreGiveFromISR
it stops at
portASSERT_IF_INTERRUPT_PRIORITY_INVALID();
Can you tell from where you call xSemaphoreGiveFromISR()?
Is that from an ISR or from a normal task context?
the mcu is atsams70 from atmel, which has contex v7 core.
xSemaphoreGiveFromISR()is call from
void TC1_Handler(void)
which is a hardware timer handler.
the timer confige is like this:
‘void configure_tc1(void)
uint32_t ul_perclk = sysclk_get_peripheral_hz();
uint32_t ul_rc_time = 0;
/* Enable peripheral clock. */
pmc_enable_periph_clk(ID_TC1);
tc_init(TC0, TC1_CHANNEL,
TC_CMR_TCCLKS_TIMER_CLOCK2 | //MCK/8
TC_CMR_WAVE |                //waveform mode
TC_CMR_WAVSEL_UP_RC |        //count up, reset on RC match
TC_CMR_ACPA_CLEAR |          //clear TIOA0 on match with RA
TC_CMR_ACPC_SET              //Set TIOA0 on match with RC
ul_rc_time = (uint32_t)((float)ul_perclk/8.0/200000);
TC0->TC_CHANNEL[TC1_CHANNEL].TC_RA = ul_rc_time / 2;
TC0->TC_CHANNEL[TC1_CHANNEL].TC_RC = ul_rc_time;
/* Configure and enable interrupt on RC compare */
NVIC_EnableIRQ((IRQn_Type) ID_TC1);
tc_enable_interrupt(TC0, TC1_CHANNEL, TC_IER_CPCS);
it is a hardware timer.
Sounds like an interrupt priority issue of the timer. Did you call NVIC_SetPriority with an appropriate priority somewhere ?
In addition please see this
and Richard’s follow up.
You should better not define global variables like data_ready_sem in a header file.
Just declare it extern SemaphoreHandle_t data_ready_sem; and define it in one c-file if you want to use it (as a global variable) in multiple c-files later on.
If it’s intended use is limited to a single c-file (e.g. the timer driver/task module) better define it as static SemaphoreHandle_t data_ready_sem; in this c-file.
Just a hint and to avoid unexpected ‘multiple definitions’ errors if you include the header file in another c-file later on.
yes, It is a problem of NVIC_SetPriority, I did not call this funciton as I’m not very clear with functions like NVIC_*.
any recommend documents/web page about these functions or about CMSIS?
Luckily only a small fraction of the CMSIS API is needed controlling the NVIC.
See e.g. the related ARM docs and the provided CMSIS (core) sources.
