dudisor wrote on Tuesday, December 03, 2013:
Hi all,
I’m new to FreeRTOS.
Try to use version 7.6.0 ported to atmega128 atxmega128A1 and CodevisionAVR.
The demo does not work. I managed to reduce the problem to a simple program:
When creating a reading queue task, the program fails, the LEDs stop flashing. Without reading queue task, the led4 flashes 5 times and then stops because the queue is full and led0 toggle every 1 sec.
If I set priority 0 for the task vReadQueue, led4 and led5 light up and stay lit and led0 not flashes. Timer intrerrupt is triggering, and program is stuck in file list.c, function: void vListInsert( xList * const pxList, xListItem * const pxNewListItem ) in the for loop.
for( pxIterator = ( xListItem * ) &( pxList->xListEnd ); pxIterator->pxNext->xItemValue <= xValueOfInsertion; pxIterator = pxIterator->pxNext ) /*lint !e826 !e740 The mini list structure is used as the list end to save RAM. This is checked and valid. */
/* There is nothing to do here, we are just iterating to the
wanted insertion position. */
// here it loops forever
I tried demo port AVR_ATMega323_WinAVR modified for ATmega128 and WinAVR and it does not work to.
#define mainLED_TASK_PRIORITY 1
#define mainTEST_QUEUE_PRIORITY 2
#define mainTIMP0 ( portTickType ) 1000 / portTICK_RATE_MS
#define mainTIMP_Q_WRITE ( portTickType ) 500 / portTICK_RATE_MS
#define mainTIMP_Q_READ ( portTickType ) 0xffff
#define mainNO_DELAY ( portTickType ) 0
//definitii prototipuri
static void vLed0( void *pvParameters );
void vWriteQueue( void *pvParameters );
void vReadQueue( void *pvParameters );
void setTestQueue(char prioritate);
static xQueueHandle xCoada;
//xSemaphoreHandle xSemaphore;
void main(void)
vParTestInitialise();
/* Create the tasks defined within this file. */
xTaskCreate( vLed0, ( signed char * )"led0", configMINIMAL_STACK_SIZE, NULL, mainLED_TASK_PRIORITY, NULL );
//vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
//vAltStartComTestTasks( mainCOM_TEST_PRIORITY, 38400, led6 );
setTestQueue(mainTEST_QUEUE_PRIORITY);
vTaskStartScheduler();
while (1)
; //nu trebuie sa ajunga aici;
xCoada=xQueueCreate(5, sizeof(char));
//xSemaphore=xSemaphoreCreateBinary();
xTaskCreate( vWriteQueue, ( signed char * ) "QProdNB", configMINIMAL_STACK_SIZE, NULL, prioritate - 1, ( xTaskHandle * ) NULL );
/* -- next task, if it is created, block all program -- */
xTaskCreate( vReadQueue, ( signed char * ) "QConsNB", configMINIMAL_STACK_SIZE, NULL, prioritate, ( xTaskHandle * ) NULL );
portTickType xLastWakeTime;
char c=0;
// Initialise the xLastWakeTime variable with the current time.
xLastWakeTime = xTaskGetTickCount();
for( ;; )
c++;
//if( xSemaphoreGive( xSemaphore ) == pdPASS )
if( xQueueSend(xCoada, &c, mainNO_DELAY ) == pdPASS )
vParTestToggleLED(led4);
vTaskDelayUntil( &xLastWakeTime, ( portTickType ) 333 / portTICK_RATE_MS );
char c=0;
for( ;; )
//if( xSemaphoreTake( xSemaphore, ( portTickType ) 10 / portTICK_RATE_MS ) == pdPASS )
if( xQueueReceive(xCoada, &c, portMAX_DELAY ) == pdPASS ) // <-- Here get stuck
vParTestToggleLED(led5);
for( ;; )
vTaskDelayUntil( &xLastWakeTime, mainTIMP0 );
vParTestToggleLED(led0);
my FreeRTOSconfig.h file:
/* Call stack size for 1 task */
#define configCALL_STACK_SIZE 32
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
#define configUSE_TICKLESS_IDLE 0
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) 14745600 )
#define configTICK_RATE_HZ ( ( portTickType ) 250 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 4 )
#define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) 65 + configCALL_STACK_SIZE )
#define configTOTAL_HEAP_SIZE ( (size_t ) ( 1500 ) )
#define configMAX_TASK_NAME_LEN ( 8 )
#define configUSE_16_BIT_TICKS 1
#define configUSE_MUTEXES 0
#define configUSE_RECURSIVE_MUTEXES 0
#define configUSE_COUNTING_SEMAPHORES 0
#define configQUEUE_REGISTRY_SIZE 10
#define configUSE_QUEUE_SETS 0
#define configUSE_TIME_SLICING 1
#define configUSE_NEWLIB_REENTRANT 0
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Hook function related definitions. */
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_MALLOC_FAILED_HOOK 0
/* Run time and task stats gathering related definitions. */
#define configGENERATE_RUN_TIME_STATS 0
#define configUSE_TRACE_FACILITY 0
#define configUSE_STATS_FORMATTING_FUNCTIONS 0
/* Software timer related definitions. */
#define configUSE_TIMERS 0
#define configTIMER_TASK_PRIORITY 3
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH configMINIMAL_STACK_SIZE
/* Interrupt nesting behaviour configuration. */
#define configKERNEL_INTERRUPT_PRIORITY 3
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 3
#define configMAX_API_CALL_INTERRUPT_PRIORITY 3
/* Optional functions - most linkers will remove unused functions anyway. */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskSuspend 0
#define INCLUDE_xResumeFromISR 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 0
#define INCLUDE_xTaskGetCurrentTaskHandle 0
#define INCLUDE_uxTaskGetStackHighWaterMark 0
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_xTimerGetTimerDaemonTaskHandle 0
#define INCLUDE_pcTaskGetTaskName 0
#define INCLUDE_eTaskGetState 0
Any help is appreciated.
Thanks in advance,
Adrian
