xQueueReceive example conflict
alsaleem wrote on Sunday, July 17, 2016:
I was viewing the xQueueReceive example in web-site
(http://www.freertos.org/a00118.html).
The code for (vADifferentTask) makes a pointer to struct AMessage
*pxRxedMessage
The description for this function says :
pvBuffer
Pointer to the buffer into which the received item will be copied
So, when calling this function, is it supposed to copy the message to my
buffer or will provide a pointer to it?
There is a conflict here. I assume queue item will be deleted after call
finishes, correct?
Thanks
Ahmad.
richard_damon wrote on Sunday, July 17, 2016:
The parameter is a pointer to the buffer, often expressed as &buffer (where buffer is the buffer to put the data into). Note that you tend to pass buffers to functions by actually passing their address as a pointer.
rtel wrote on Monday, July 18, 2016:
Perhaps the following will help? http://www.freertos.org/Embedded-RTOS-Queues.html
