paulgcoleman wrote on Wednesday, December 19, 2012:
If I use a block time of zero is it safe to use xQueuePeek() inside an ISR?
Thanks, Paul.
Thanks, Paul.
rtel wrote on Wednesday, December 19, 2012:
You can’t use the existing peek function from an ISR, but could add something like the following (not actually tested!)
signed portBASE_TYPE xQueuePeekFromISR( xQueueHandle pxQueue, void * const pvBuffer )
signed portBASE_TYPE xReturn;
unsigned portBASE_TYPE uxSavedInterruptStatus;
signed char *pcOriginalReadPosition;
uxSavedInterruptStatus = portSET_INTERRUPT_MASK_FROM_ISR();
/* We cannot block from an ISR, so check there is data available. */
if( pxQueue->uxMessagesWaiting > ( unsigned portBASE_TYPE ) 0 )
/* Remember the read position in case we are just peeking. */
pcOriginalReadPosition = pxQueue->pcReadFrom;
prvCopyDataFromQueue( pxQueue, pvBuffer );
/* The data is not being removed, so reset the read pointer to its
original position. */
pxQueue->pcReadFrom = pcOriginalReadPosition;
xReturn = pdPASS;
xReturn = pdFAIL;
portCLEAR_INTERRUPT_MASK_FROM_ISR( uxSavedInterruptStatus );
return xReturn;
