I am trying to build my code using the v4.00 xc32 compiler. I am integrating the source files required to have FreeRTOS scheduler running with my code but I am experiencing the following error when building portasm.c
"/opt/microchip/xc32/v4.00/bin/xc32-gcc" -g -x c -c -mprocessor=ATSAML10E16A -fno-common -MP -MMD -MF "build/default/production/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o.d" -o build/default/production/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.c -DXPRJ_default=default -mdfp="/home/user/.packs/mhcp/Microchip.SAML10_DFP.3.6.95" -I "/home/user/.packs/arm/CMSIS/5.4.0/CMSIS/Core/Include" -I "rtos/include" -I "rtos/portable" -I "rtos/portable/GCC/ARM_CM23_NTZ/non_secure" -I.
/tmp/cc9CNPey.s: Assembler messages:
/tmp/cc9CNPey.s:118: Error: instruction not supported in Thumb16 mode -- `bics r0,r1'
/tmp/cc9CNPey.s:149: Error: instruction not supported in Thumb16 mode -- `orrs r0,r1'
make[1]: *** [Makefile-local.mk:149: build/default/production/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o] Error 255
This is incorporated in my Makefile as follows (I don’t think there is any problem here):
${OBJECTDIR}/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o: rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.c
@${MKDIR} "${OBJECTDIR}/rtos/portable/GCC/ARM_CM23_NTZ/non_secure"
@${RM} ${OBJECTDIR}/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o.d
${MP_CC} $(MP_EXTRA_CC_PRE) -g -x c -c -mprocessor=$(MP_PROCESSOR_OPTION) -fno-common -MP -MMD -MF "${OBJECTDIR}/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o.d" -o ${OBJECTDIR}/rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.o rtos/portable/GCC/ARM_CM23_NTZ/non_secure/portasm.c -DXPRJ_default=$(CND_CONF) $(COMPARISON_BUILD) -mdfp="${DFP_DIR}" ${PACK_COMMON_OPTIONS} ${PACK_FREERTOS} -I.
Any ideas what I am doing wrong? I have tried both v3.01 and v4.00 xc32 compilers and the same problem exists. Does anyone have an example Makefile for an application using FreeRTOS?
The version of FreeRTOS that I am using is: FreeRTOS 202112.00
