SMP is being tested in dual core by referring to the above code.
I have created several tasks only in Core0,
Core1 has only an idle task created.
Therefore, task context switches rarely occur between cores.
At a certain point, the ELR_EL3 value stored in the stack in the portSAVE_CONTEXT macro suddenly becomes 0x0.
Therefore, the portRESTORE_CONTEXT marker generates an undef handler because the ELR_EL3 value is 0x0.
At this time, the stored SPSR_EL3 value is “0x0010000d”.
If it is set to MSR SPSEL, #0, it should be M[3:0] = b1100: EL3t.
Why is it b1101:EL3h?
To be precise, the ELR_EL3 value to be stored in the stack itself is 0x0…
I wonder why ELR_EL3 value is 0x0.
I have another question.
Is it okay to jump directly to the IRQ handler because IRQ occurs during the SWI_Handler () function operation called through SMC instruction?
Or should I go to IRQ handler after returning to task from SWI_Handler() and becoming IRQ enabled?
I think my previous comment was not correct. Based on my reading so far, on Cortex-A, interrupts are disabled as soon as you take an exception and are not re-enabled unless explicitly enabled.
How did you verify that an IRQ was taken by the core while handling SMC?
The following is from the architecture manual -
When taking an exception to EL3, ELR_EL3 holds the address to return to.
If ELR_EL3 is 0x0, that means exception was taken from address 0x0. Is 0x0 a valid address or somehow control is reaching an invalid address? Also, which interrupt is firing?
Would you please help me understand this question?
When the processor takes an exception to AArch64 execution state, all of the PSTATE interrupt
masks is set automatically. This means that further exceptions are disabled. If software is to
support nested exceptions, for example, to allow a higher priority interrupt to interrupt the
handling of a lower priority source, then software needs to explicitly re-enable interrupts.
Your statement is right.
I misdefined the portCLEAR_INTERRUPT_MASK in portMacro.h
I think it was a problem because IRQ was enabled unconditionally.
the problem was solved by defining portCLEAR_INTERRUPT_MASK as portRESTORE_INTERRUPTS.
Thank you for your help.
