Wireless FreeRTOS IP stack
Hi
I would like to know if there is an implementation of the FreeRTOS IP stack running on a Wireless interface.
I am looking for an alternative to the ESP32 running lwIP stack on its wireless interface.
Can you tell in which demo board this has been implemented?
thanks,
Eduardo
Hi @EduardoGoncalves1966
Thanks for reaching out to the FreeRTOS Forum community!
FreeRTOS, by design, uses the vendor specific WiFi APIs directly with a TCP/IP and network transport layer in between.
FreeRTOS+TCP has a network interface implemented for ESP32 board here
You can use it to replace the default Lwip , ESP IDF currently implements.
The best place to look at for these will be the ESP IDF at GitHub - espressif/esp-aws-iot: AWS IoT SDK for ESP32 based chipsets. This has some good examples which can be referred in the folder “examples”.
Apart from ESP32, FreeRTOS+TCP has also been implemented on the wireless interface in the Pic32 board
FreeRTOS-Plus-TCP/NetworkInterface_wifi.c at main · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
Hi
Thanks for the fast answer and the links.
I am more interested in implementing an Application that will communicate using UDP broadcasts (without Access Points. Just like if it was running on Ethernet). And also creating a TCP connection to communicate between 2 systems.
Is there a simple project for this? I inspected the directory and it seems there are implementations for complex protocols like MQTT, HTTP, etc.
I am looking for something as simple as possible that allows to use TCP connections and UDP broadcasts.
thanks
Did you look at this one - FreeRTOS/FreeRTOS-Plus/Demo/FreeRTOS_Plus_TCP_Minimal_Windows_Simulator/DemoTasks at main · FreeRTOS/FreeRTOS · GitHub
Hi
Does that example run on a WiFi interface?
One thing that I don’t understand is on hopw to choose the interface that the TCP/IP stack should use:
xListeningSocket = FreeRTOS_socket( FREERTOS_AF_INET, FREERTOS_SOCK_STREAM, FREERTOS_IPPROTO_TCP );
When a socket is created how does one associate this stream with Ethernet or WiFi?
thanks
Hi @EduardoGoncalves1966,
It depends on what port you’re using for the platform.
Take esp32 as example, the xNetworkInterfaceOutput is the interface for FreeRTOS-Plus-TCP to transmit output packet through the network interface. And esp_wifi_internal_tx() is esp32’s wifi API!
You can also try this Networking Demo Project. It uses libpcap as network interface on top of Linux, support on any available network interfaces on your machine.
Thanks for the answers.
Although I am looking for an example project where a TCP connection is being made between two ESP32 boards, ideally ESP32-WROOM.
Also a UDP broadcast example would be nice but I think when I have a the TCP project I can make this one.
Any help? Thanks.
You can refer to the demo FreeRTOS/FreeRTOS-Plus/Demo/FreeRTOS_Plus_TCP_IPv6_Demo/IPv6_Multi_WinSim_demo at devIPv6 · FreeRTOS/FreeRTOS · GitHub. This creates multiple endpoints. For ESP32, you will will have to use the ESP32 portable layer(FreeRTOS-Plus-TCP/source/portable/NetworkInterface/esp32 at main · FreeRTOS/FreeRTOS-Plus-TCP · GitHub) instead of the libpcap portable layer.
Can someone help setting up an example?
i am struggling with idf and cmake. So it is maybe more a esp-idf question,…
I started a normal idf project and freertos-plus-tcpip is a submodule
set(FREERTOS_PLUS_TCP_NETWORK_IF "ESP32")
add_subdirectory(../submodules/FreeRTOS-Plus-TCP freertos_plus_tcp)
lines in the main/CMakeLists.txt
dependencies needed:
freertos_plus_tcp need
target_link_libraries( freertos_plus_tcp
  PUBLIC
    freertos_config
    freertos_plus_tcp_port # for pack_struct_start.h
  PRIVATE
    freertos_kernel
    freertos_plus_tcp_network_if
    freertos_plus_tcp_utilities
and ESP32 networkdriver
target_link_libraries( freertos_plus_tcp_network_if
  PRIVATE
    esp32_lib
At idf idf BuildSystem there are some info how to achieve what i need but i cannot set up a working example.
Do i have to follow the idf component way or go the plain cmake way with idf as library?
I think using the IDF component way would be easier but I’d suggest to reach out to Espressif and confirm with them.
